24-Bit Adat Bridge broken or not ?
Hi there,
I just got a 24-bit adat bridge but I'm having troubles with it. When I select any of the adat inputs I just get alots of hard ( almost white ) noise out of them. The adat bridge is connected on the legacy port of my 192 D with the propper Y cableling. It's setting up fine in the hardware setup and peripherals, shows up in the I/O menu and even all leds are following. Clock is connected from the 192 and seems to be syncing perfectly. Nothing is wrong with the legacy port itself on the 192 D as I tried 2 diffrent ones with same noisy result. Also no problem with the convertors / devices hooked up to the adat ports as they seem to clock nicely even from the adat bridge. So my question is : is the adat bridge just broken or am I missing something here ? Best Regards Steve |
can i pass adat from a 003r to an adat bridge | Filmusic | Digidesign Hardware & Software | 4 | 09-04-2010 07:22 PM |
ADAT to PTMixPlus via ADAT bridge...digital pops? | Phattlippz | Digidesign Hardware & Software | 2 | 05-28-2006 05:13 PM |
ADAT bridge: same as ADAT lightpipe cable? | Jim S | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-16-2001 07:37 AM |
PT/ADAT Bridge/Fostex ADAT/USD/Beta...... | Raven | Pro Tools TDM Systems (Mac) | 1 | 12-27-2000 06:27 AM |
cable lenght (fiberoptics) adat to adat bridge | olek | Pro Tools TDM Systems (Mac) | 10 | 02-21-2000 07:47 PM |
