Old 02-20-2019, 10:17 AM
TrentWilliams TrentWilliams is offline
Default Has Signal Generator Changed?
Hey everyone,
I just went to render some pink noise and was shown a dialog box exclaiming 'no audio was selected'. From memory isn't it just supposed to render a new file on the timeline? It works if I pre-render a region and then render that region with Signal Generator. But from memory I usually don't have to take this extra step.
Can anyone confirm?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 02-20-2019, 04:44 PM
Sardi Sardi is offline
Default Re: Has Signal Generator Changed?
If you’re rendering a file with Audiosuite, you just select the length in the timeline and process it.
If you’re doing it in real-time, you’ll need to BTD, Commit it route it to a new track.
It’s always been this way.
Old 02-20-2019, 10:51 PM
Hi Sardi, thanks for the reply.
Yip that’s 100% correct - I’m using audiosuite. It’s forcing me to pre-render/consolidate a region prior to processing with sig gen otherwise it splashed back citing ‘no audio selected’. I can’t just select a region of whatever length and hit process anymore.
Old 02-20-2019, 11:44 PM
jchan jchan is offline
I was just about to confirm the issue but figured it out.
It has to be an Audio track, mono or stereo. Doesnt work on other tracks.
/J
Old 02-21-2019, 12:30 AM
Hey all,
Thanks for the replies. I had just done a screen capture, was about to upload when I noticed I had 'Create Individual Files' selected, instead of 'Create Continuous File' - *RookieMoment.
Thanks again for your suggestions.
Signal Generator my-name-is-thanos Pro Tools 12 15 03-13-2024 10:48 AM
Use of a signal generator reverieman Pro Tools TDM Systems (Win) 1 10-25-2006 06:59 AM
Signal Generator gone!!!! clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-05-2003 03:22 AM
Signal Generator Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-09-2002 05:56 AM
signal generator for what use? jinsel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-11-2002 03:01 PM
