Old 03-22-2002, 07:15 AM
Eric Heil Eric Heil is offline
Default Multi Monitor and windows
Hey guys!
I have a SIS 300 video card that lets me use multi monitor but I don't know how to set up PT LE for Multi Monitor use.
Who's got a clue?
Eric [img]images/icons/confused.gif[/img]
"Done right, on time and on budget..."
Eric Heil
Angelic Productions, LLC
More Pro Tools rigs than I can shake a stick at...
www.AngelicLive.com
FaceBook Me!
Old 03-22-2002, 01:41 PM
omikron omikron is offline
Default Re: Multi Monitor and windows
if you have correctly installed the drivers of your video card, you should be able to "activate" the second monitor in your windows display properties. Then you'll have to "Restore down" PTLE (middle button of the 3 in the right upper corner of each standard windows task) and expand it manually over the 2 monitors. It's very boring that you have to do this each time because PT doesn't remember the last window size/setup.
CU,
Omikron
Old 03-22-2002, 08:52 PM
I've got my cursor moving over to my 2nd monitor but I can't move the window past monitor 1. I can go right to the edge but no farther.
Eric [img]images/icons/cool.gif[/img]
Eric Heil
www.AngelicLive.com
FaceBook Me!
Old 03-22-2002, 09:50 PM
recordingguy recordingguy is offline
You have to resize ProTools main window.
Just minimise Protools, then grab the corner and drag it untill it is on both screens/monitors.
then you can fit the mix on one screen and the edit on the other.
You can't just drag the mix or edit window to the other monitor with ProTools at this time...Maby with the next update...
P.S. You will need to do this every time you open ProTools because PTLE dosent remember the settings...
Hope this helps.
Good Luck!!! [img]images/icons/grin.gif[/img]
recordingguy
Recording Guy's Studio & Sound
www.recordingguy.com
Cedar Rapids, IA
Does 10 still have the bug if Input Monitor is on a multi-channel track Craig F Pro Tools 10 0 05-05-2012 06:17 PM
Multi-Monitor Setup: Detached/Floating Window jrlanglois Pro Tools 10 7 12-29-2011 01:06 AM
Multi-Mode Windows M-ManLA ICON & C|24 3 08-23-2009 06:07 PM
multi-monitor systems edriver Pro Tools M-Powered (Win) 9 03-17-2008 11:51 AM
Multi Monitor set up donrey ProControl, Control|24, Command|8 1 02-14-2006 09:03 AM
