Old 03-06-2018, 08:24 AM
dawand dawand is offline
Default Logic X 4.1 Crashes Regularly because EuCon
Logic crashes indicating the EuCon library was the issue.
Also the surfaces freeze a lot and I have to restart EuCon, the surfaces and Logic to get them back.
It will happen at least once every two hours.
3.7, with an MC Mix, and an MC Transport, all on the most recent firmware.
Logic 10.4.1, High Sierra is at the current patch level.
Old 03-06-2018, 06:23 PM
EddieJones's Avatar
Default Re: Logic X 4.1 Crashes Regularly because EuCon
Can you send me the crash text. We know and have reported a crash to Apple that happens with plugin knobs so want to see if its the same. Also please report to Apple.
Old 03-07-2018, 08:59 AM
Will do.
Old 03-13-2018, 03:45 PM
Ok here's the repeatable steps that bring this on.
Working in Logic Pro 10.4.1 for several hours (two in this case).
Control surfaces locked to logic pro.
I switch away to do something (in this case it involved using Alfred 3 to load OSX Screen Sharing - but often it happens if I go check OBS or TotalMix).
I come back to Logic and they're frozen.
This time I left them long enough for them to actually "pop" back to no-app mode. (Which to me is indicated by blank rectangles on the MC Mix.)
Eventually I finish what I'm doing an quit Logic. As soon as logic is closed I get a notice that EuControl crashed.
I copied the entirety of the crash output from the dialog and put it in a PDF for you.
Old 03-14-2018, 07:19 AM
EddieJones's Avatar
The engineer thinks he found the issue from that crash dump and already fixed it. Thanks for the help.
Old 03-19-2018, 08:45 AM
Glad t hear it. Thank you!
Old 03-19-2018, 09:19 AM
EddieJones's Avatar
This is in the release now
Eucon crashes planck Avid Pro Mixing General Discussion 23 09-14-2018 09:20 AM
Does S6 install Eucon/Eucontrol ? Logic crashes... vudoo Avid S4/S6 5 05-03-2016 10:46 AM
eucon 3.0 crashes tandri79 Artist Series 7 06-24-2013 01:24 PM
PT10 crashes regularly when stopping playback arjohe macOS 1 09-29-2012 06:37 AM
importing video regularly crashes 7.4cs2 uno1234 Pro Tools TDM Systems (Mac) 5 03-30-2008 10:24 AM
