Midi input stopped working on Mbox 2 Pro
I have had my Mbox 2 Pro for almost 3 years now. Now when I decide to work only in Reason 4.0 the midi controller is not detected via Mbox 2 Pro Midi. I have ran the midi loop test light lit up. I seen no reason to swap the cable as the midi controller is detected in Reason and PT on my EZBus midi ports.
Please help Thanks |
Re: Midi input stopped working on Mbox 2 Pro
Are you using Reason rewired into PT? If so, on Windows machines, PT "steals" the MIDI hardware.
Most people, when using Reason with Pro Tools just do their sequencing in Pro Tools, so this problem really doesn't matter. If you absolutely need to do your sequencing in Reason while rewired to PT, there is a workaround, but it only works for USB connected MIDI devices:
This will allow you to use the MIDI device in Reason while rewired. It will not work for devices that are plugged into the MBox 2 Pro using standard MIDI cables.
I'm noticing in device manager, under sound, video and game controllers it has nothing about Mbox 2 Pro midi it only list the devices below.I have also listed some info about my computer after running msinfo32, if need be I will run a Sandra report.
Audio Codecs Digidesign Mbox 2 PRo Ezbus Control Surface Engine Legacy Audio Drivers Legacy Video Capture Devices Media Control Devices USB Audio Device Video Codecs OS Name Microsoft Windows XP Professional Version 5.1.2600 Service Pack 2 Build 2600 OS Manufacturer Microsoft Corporation System Name PRO-TOOLS System Manufacturer Supermicro System Model X6DVL-EG2 System Type X86-based PC Processor x86 Family 15 Model 4 Stepping 10 GenuineIntel ~3000 Mhz Processor x86 Family 15 Model 4 Stepping 10 GenuineIntel ~3000 Mhz Processor x86 Family 15 Model 4 Stepping 10 GenuineIntel ~3000 Mhz Processor x86 Family 15 Model 4 Stepping 10 GenuineIntel ~3000 Mhz BIOS Version/Date American Megatrends Inc. 080010, 3/29/2005 SMBIOS Version 2.3 Windows Directory C:\WINDOWS System Directory C:\WINDOWS\system32 Boot Device \Device\HarddiskVolume1 Locale United States Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" Total Physical Memory 2,048.00 MB Available Physical Memory 2.41 GB Total Virtual Memory 2.00 GB Available Virtual Memory 1.96 GB I have 4 SATA drives with my PT Sessions on drive G:\. Thanks |
It seems as though Pro tools is not installing the midi drivers. I 'm able to see the Digidesign Mbox 2 Pro midi All and 1-16 channels on a midi track but when I select one of them with my midi controller plugged into the Mcbox no signals are going through it.
Please help this is driving me nuts. Thanks |
Guitar Input Stopped working - | DUlrich | Eleven Rack | 15 | 06-05-2011 08:13 AM |
MIDI input not working Mbox 2 | AndySolomon | macOS | 10 | 01-16-2011 01:12 PM |
My spdif input stopped working (003) | Paul David | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2010 10:23 AM |
Why has midi input stopped working except with Midi Thru enabled? | Martin Dubka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-11-2008 07:43 AM |
lightpipe input stopped working | jgehring | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-26-2002 07:55 AM |
