Old 01-31-2007, 08:45 AM
icenet icenet is offline
Default AudioSuite Question
So I processed some dialogue with an AudioSuite plug-in a while back. The files now have a prefix "WDXN." I don't remember what plug-in I used. Is there any way to trace this back and find out by the prefix? Thank You.
Old 01-31-2007, 10:24 AM
25ghosts 25ghosts is offline
Default Re: AudioSuite Question
mostly the prefix can be logically located by using the grey cells in your upper region)))) Since I dont know which plugs you have installed I cant really help you. Have a look at you plugs and try n figure it out. AFAIK there's no command for locating old audio suite edits...
Good Luck
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 01-31-2007, 10:40 AM
Can you explain what area you are refering to? Thanks
Old 01-31-2007, 11:19 AM
grey cells in the upper region = Brains))
open one of your audio suite plugs and apply on some region - look at the naming and then at the plug-in you used - there you should be able to gather the key from the prefix added
Old 04-17-2017, 10:03 AM
lefa lefa is offline
That's Morphoder.
I've never found a list, but there's a few I got used to.
General rule: if it's a plugin with mono and stereo version, the mono audiofile will end with N and the stereo one with T.
Old 01-24-2023, 01:26 AM
Stefano Giannotti Stefano Giannotti is offline
Originally Posted by icenet View Post
Hello, the file WDXN comes from the Morphoder Mono in the Protools audiosuite.
AUDIOSUITE QUESTION and others! TREXROCK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-12-2008 01:04 AM
question about audiosuite Souf Centrol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-06-2008 12:14 AM
Question about Audiosuite... JChance Pro Tools M-Powered (Mac) 1 12-26-2007 10:06 PM
Audiosuite Question gracejames 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-25-2007 11:13 PM
Audiosuite question ejwells 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-03-2004 04:45 PM
