Old 01-03-2005, 01:45 AM
Aquarius Aquarius is offline
Default Advices on OS X maintain, cocktail menus....
Just bought Cocktail after reading posts on this forum
What is the best procedure when it comes to os maintenance ? How often do you use this soft ?
Can someone explain to me why we have to clean the caches.... ?
Old 01-03-2005, 07:17 AM
TCDet TCDet is offline
Default Re: Advices on OS X maintain, cocktail menus....
The "Cocktail' script running application has cured Mac behaviors for me.
The OSX system uses virtual ram scratch disk. i.e. hard drive for ram cache.
Ideally your boot drive should have 20 Gb or better of space. if my Mac got too much below this I noticed a operational speed slow down.
In Cocktail I use the clean virtual swap file and occasionally the clean system cache. The cron script if you do not leave your Mac on 24-7. This is a Mac maintenance script that runs automatically in the middle of the night.
The repair permissions I do from the Mac’s Disk utility. I am not sure of the difference but the Mac repair if ran after cocktails seems to repair additional items.
I figure this is due to the OS updating being more current than cocktail.
I am using Cocktail 3.4.9 Mac OS 10.3.6
Pro Tools 6.7 cs5, Mac Quicksilver 2002 Dual G4.
I also use Disk Warrior as part of my Mac maintenance routine.
Old 01-03-2005, 07:46 AM
AVGuru1 AVGuru1 is offline
Since OS X does a lot of the cleanup for you, I just use ONYX to repair permissions, clean your cache, etc. Very nice. Much easier than entering the commands via terminal. As long as you remember to reboot twice after running it, you're golden. I've been using it weekly (and after installing apps, as sometimes the installers don't clean up or optimize as well as they should) and running PT with no issues.
http://www.versiontracker.com/dyn/moreinfo/macosx/20070
Good Luck!
EDIT: If you are interested, I can post the UNIX commands
.: michael kammes mpse
.: post audio
.: applications editor / workflow consultant
.: michaelkammes.com
.: lucidsound.com
Old 01-03-2005, 08:02 AM
jimlongo's Avatar
jimlongo jimlongo is offline
I like Applejack because it runs from the command line before launching the UI.
Then if your computer is not on 24/7 I use MacJanitor to manually run the cron scripts. You can also run them from the command line with sudo periodic daily, sudo periodic weekly, and sudo periodic monthly.
noise | jimlongo
Old 01-03-2005, 09:01 AM
Jim, yes Mac Janitor is great!
ONYX incorporates all that mac janitor does and more.
(essentially, mac janitor just does what your mac is supposed to do every morning at 2 am, but since I don't leave my mac on, I lose out!)
.: post audio
.: lucidsound.com
Old 01-03-2005, 10:42 AM
Thanks to everybody !
Best wishes for 2005 !
Olivier
Old 03-17-2023, 04:16 PM
skeepinfleebin skeepinfleebin is offline
Hey Aquarius do you know Mike Olson? He told me you were his buddy stormtrooper #88 im his stormtrooper and im looking for software sony pegasus. Is it still on this website or do you have it? Ive been looking everywhere. Im looking to be a badass stormtrooper in space and im looking for help. Everyone told me this is the place to find it. Please help im Mike Olsons stormtrooper. Thanks.
Onyx or Cocktail? smpkeys Pro Tools TDM Systems (Mac) 3 09-28-2010 01:03 PM
New version Cocktail software available Park Seward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-20-2007 07:04 PM
cocktail ??? bbob Pro Tools TDM Systems (Mac) 10 03-21-2005 11:33 AM
How do you maintain your mac and drives? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 34 02-01-2003 12:20 AM
PT LE 5.01, G3 Beige and 9.1, a nice cocktail? quisco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-03-2001 04:59 AM
