Old 01-21-2024, 05:12 PM
whitebalance whitebalance is offline
Default Auto splice by volume?
Hello, is there anything that can detect when the volume drops on a clip to a specified dB, then adds an edit, and then when the volume raises to a specified volume adds an edit?
I’m using Defaulter to auto adjust clip gain, but there is too much dynamic range within some clips, so Defaulter ends up averaging too much or too little.
Old 01-21-2024, 07:16 PM
audiolex1 audiolex1 is offline
Default Re: Auto splice by volume?
What exactly are you needing something like that for?
I know there are plugins from waves that will adjust volume in the plugin, but not the audio.
Sometimes it is just easier to use clip gain and do it manually.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 01-21-2024, 08:10 PM
I’m using Defaulter to automatically get my clip gain close. It does a pretty good job. However, I still have to manually splice words or phrases, if there is too much dynamic range in a clip. Otherwise Defaulter average too much or too little, and the clip is too loud or too quiet.
If we can tap to transients, strip silence, quantize beats, we should be able to set volume thresholds to add edits.
Manually riding faders, or physically splicing edits and manually adjusting clip gain (even with keystrokes), shouldn’t be necessary just to even out dialogue in this age of AI.
WaveRider and other Plug Ins can write automation post fader, but I’m trying to even things out before they hit the compressor.
Old 01-22-2024, 05:51 AM
its2loud its2loud is offline
This is called mixing but if you want a “normalizer” plug-in, use the stock one or go to Waves MV2 or Soundradix Powair.
These don’t splice but you don’t need to splice.
HTML code is On
Splice and protools chonapelon AAX Plug-ins 12 10-02-2023 09:46 AM
AAF 'splice with no handles' bug paranerd Post - Surround - Video 0 06-12-2014 05:51 AM
How to butt splice several regions? Vovique 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-25-2010 02:24 AM
Auto pan and volume question paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-31-2007 06:46 PM
adjusting volume of track with vol auto on it Equality 7-2521 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-22-2005 01:36 PM
