NULL Command Under System Configuration Utility
Need some information from the PC Gurus. I now have two computers, one dedicated to PT LE. I'm in the process of tweaking the startup items with msconfig. However, I have found a startup item that I cannot identify. Here's the line under the Startup Tab:
Startup Item: NULL Command: NULL Location: HKLM\Software\Microsoft\Windows\CurrentVersion\Run When I run msconfig on my Internet computer, no such Command under the Startup Tab. Does anyone know what this Command is and why it would be on one machine and not another? The PT computer is brand new, so it's never been on the Net and isn't networked with the other computer so I don't think it's a Trojan. As always, your help is much appreciated. Cheers,
Re: NULL Command Under System Configuration Utility
Bump
if it dont link to anything its pointless, just delete it, dont know which software would have created such a thing, you can search google and see if anyone else has similar
Google Null search here if you delete it and it comes back after reboot then id be concerned and investigate more (e.g install a AV program and download latest virus def's then scan whole system). |
Thanks Booyah, anyone else?
Cheers,
D-Command Configuration Help | postman56 | ICON & C|24 | 6 | 01-29-2014 10:03 AM |
System 5 Brightness Utility | PhilippeCNA | System 5 | 2 | 12-23-2011 01:36 AM |
System drive back up with disk utility question | crizdee | Pro Tools TDM Systems (Mac) | 2 | 06-19-2005 01:58 AM |
Protools LE & XDV on same XP system utility test | michaelmovies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-10-2003 12:01 AM |
System Configuration | Mitmont | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-20-2002 05:46 PM |
