Old 05-18-2008, 01:53 AM
alockstrom alockstrom is offline
Default JAGGED CLICK & COUNTER DURING RECORDING
Iīm having problems with my Pro Tools 7.3.1cs to start recording.
I just got a Dell XPS m1530 (3g ram, 2,4Ghz Double-Core, 7200rpm harddrive (internal), and have installed it with Mbox 1 (connected via usb), Windows XP and all the drivers that are needed and everything is working except that when Iīm in Pro Tools and have setup everything for recording for example a audiotrack, when I try to record the counter move slowly (at first not at all) and when Iīm using a click it just jags (donīt know if itīs the right word in english, BUT the click and counter is not even).
The cpu usage is not high at all! And I have had my friend who knows quite a lot about PT to do PT-tweaks and settings. And he canīt find the solution of the problem. Could it be something with midi-sync?
When Iīm using for example plugins and stand-alone instruments like Amplitube, Guitar Rig, Akoustik Piano, B4 II theyīre working just fine. So it doesnīt seem to be the computers power that is the problem.
What can the problem be?
Would the PT 7.4 work better? Or maybe earlier versions or with Vista?
I just want and need this to work!
Thanks for your help!
Old 05-18-2008, 03:11 AM
mano111 mano111 is offline
Default Re: JAGGED CLICK & COUNTER DURING RECORDING
Sounds like you havent installed the dual core hotfix. that one is a must
also good idea would be to read the XP troubleshooting thread and implement all the nececery tweaks listed.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 05-18-2008, 03:19 AM
How do I install dual core hotfix??
And you mean the troubleshooting XP in Digidesigns site?
Old 05-18-2008, 03:41 AM
general troubleshooting thread XP
its a thread in the LE forum's first page
if you're running a dual-core processor, make sure to install the Windows XP Dual Core Hotfix:
http://support.microsoft.com/kb/896256
Old 05-20-2008, 01:14 AM
Iīve tried both the hotfix and the XP-settings that you recommended, but I still have the same problem.
When Iīm hitting record and play either the click jags or the recording wonīt start!
Whatīs the problem? Could it be that my laptop compatibility sucks?
Old 05-20-2008, 05:07 AM
spkguitar's Avatar
Hard to say without more details about it. (but probably so) What you posted above is too basic/generic for any of us to say for sure.
You said you are recording to the internal hard drive? There are a few reasons why that is not recommended; most laptop hard drives are too slow for streaming audio to/from, normal operations of the system can interfere with streaming audio to/from the drive, and most times errors occur when you do.
Old 05-20-2008, 05:29 AM
tkalayci tkalayci is offline
Hi, I had the same problem and the hot fix absolutely fixed it. Are you sure you made the registry change? The value should be set to 1 (ms article seems confusing). Here's a link with screenshots:
http://blog.empas.com/bluent/read.ht...77333&c=258396
Old 05-20-2008, 09:58 AM
I cant find the hotfix under install/uninstall programs when I have tried to install it. I must have the Swedish version, since my OS is swedish. When I try the english hotfix it says that itīs not compatible with the language on my OS. I thought I had installed it, but now I see that I havenīt. I donīt get a window that says that my computer should be restarted. Instead the window says that the installation of the file is being finished and then I click finish and the window closes and nothing happens.
Old 05-20-2008, 10:15 AM
spkguitar's Avatar
On this Microsoft page you can change the language to Swedish before you download.
If you have any problems after that, you really should contact Microsoft.
Old 05-20-2008, 02:07 PM
It doesnīt seem that the hotfix is installed right for me! Directions told me that a window should come up which says that Iīm going to restart my computer, but it doesnīt! I only get a window that says that I should click finish to finish the installationsprocess of the hotfix, but nothing more happens! And I canīt locate that it is installed either... what can this problem be?
/alockstrom
Click/counter stuck on 8th notes dankin macOS 1 09-25-2012 03:15 PM
Main Counter doesn't update when I click the timeline Grizz1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-25-2011 06:40 PM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
HELP!!! Bizzare click track/counter problem oneson2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-16-2005 07:45 AM
Jagged waveform drawing ajs Pro Tools TDM Systems (Mac) 2 11-19-2004 03:28 PM
