Old 02-09-2006, 09:19 AM
Dopebeat Dopebeat is offline
Default Bizzare DSP/CPU feedback problem ?!?!
Ok, my rig:
Ptool LE 6.8
Mbox 2
PC with 2.8 clock and 512 ram (yes I am going to upgrade the RAM)
My problem:
I was configuring a dual-mono reverb bus last night. So I could have one side of the D-verb set one way, and the other, the other way. I could choose between which side of the "unchained" reverb I wanted and how much I want piped from each audio channel.
3 audio channels, and the 1 D-verb auxilliary input channel. So I am not doing much here at all.
Everything runs fine, but when I pause play, my CPU usage meters jumps from about 10 percent up to 70-80 percent ! When I press play again, it all falls back down to normal.
After some tooling around, if I give the D-verb no inputs during pause, the CPU meter falls back to normal, if I disable the D-verb channel, everything goes back to normal during pause.
So, while the D-verb bus is not processing any signal and lying idol, I am getting some type of idle feedback loop or something. The only way around it seems to be to disable the D-verb during pause. This cannot be the way it is meant to be !
Maybe there is some preference, or something I need to configure so that all DSPs are automatically disabled during pause or something ?
Thoughts ? Help ? A shotgun ?
Old 02-09-2006, 09:30 AM
spkguitar's Avatar
Default Re: Bizzare DSP/CPU feedback problem ?!?!
You are experiencing "Denormalization". Here's an explanation (read all 3 pages)
Short solution; insert a dither plugin before the D-Verb.
Old 02-09-2006, 09:44 AM
Right on, THANK YOU !!!
Feedback problem obiwan177 VENUE Live Sound Systems 3 02-16-2010 03:52 PM
Feedback problem!! HELP! Greeno Pro Tools M-Powered (Mac) 5 12-04-2008 08:59 AM
HELP!!! Bizzare click track/counter problem oneson2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-16-2005 07:45 AM
Feedback Problem... malfunction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-21-2005 09:46 AM
Feedback Problem... malfunction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2005 02:36 AM
