Old 05-09-2014, 05:04 PM
kolor2013 kolor2013 is offline
Default Delay plguins bug/problem?
Hey everyone
I've got a specific problem, because i tried almost everything what have been told to do in this type of situation, but here is what is happening: most of delay plugins (not everyone) when i try to use them they are causing an offbeat for ex - of my vocal. It is like the original waveform is moved few seconds to the right side (ofcourse i do not see this but i just want to describe this issue as simply as it is possible ). For example in echoboy when it is on 1/2 , i've watched mixnotes on youtube and he has got there a nice tutorial for a delay throws, so i decided to try this. He has got no problem with echoboy when it is 1/2 or whatever, but when i try to do the same thing, the whole thing is messed up, vocal just goes off the beat. I tried delay compensation etc. It is not helping at all. EVEN the basic pro tools delays like short delay or long delay causing the same thing. Could you help me? Because i canno't go further with my music production because of this, you know delays are very useful things to do specific effects in your tracks.
Sorry for my english.
Old 05-10-2014, 02:36 AM
Stig Eliassen's Avatar
Default Re: Delay plguins bug/problem?
Welcome to these forums.
We need some more info about your setup. I see in your profile that you have Pro Tools HD 10? Which version of PT is this exactly? Mac or PC?
Also, what are your settings in the Playback engine?
Old 05-10-2014, 02:56 AM
It is an PC version. Currently my settings are :
Buffer size - 256 samples
host processors - 3
cpu usage limit - 90%
delay compensation engine - i tried all of the values - but often i choose "long"
cache size - normal
Old 05-10-2014, 04:21 AM
Thanks.
Now, which version of Pro Tools are you using? 10.x.x?
Do you have the conductor (tempo map) enabled, or are you using a manual tempo? Do you have the MIDI button enabled in Echoboy?
I think it's strange that only some of your plugins doesn't behave as expected.
Old 05-10-2014, 03:21 PM
It is 10 3 2
i'm using manual tempo, yes midi button is enabled
Old 05-11-2014, 01:42 AM
Where is Echoboy inserted, and how are you sending the vocal signal to it?
Delay problem... Mofoman Pro Tools M-Powered (Win) 1 01-08-2010 08:08 PM
M-Audio Delay Problem DJLilSteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2007 05:04 PM
Delay Problem gstockton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-25-2005 10:58 PM
plguins for pt free pellegrini Digidesign Hardware & Software 0 06-22-2003 12:58 AM
delay problem willidrum Digidesign Hardware & Software 1 04-26-2002 05:40 AM
