Old 09-23-2013, 07:21 AM
aldersyde aldersyde is offline
Default Pro Tools freezes - "restoring audio playlists"
I am running Pro Tools 10.3.7 on a PC.
When I open up old songs or songs which I am collaborating from sent from a different user the program freezes while Pro Tools says it is "restoring audio playlists".
I'd like to know how to fix this or if I should go back to an earlier version.
Old 09-23-2013, 08:26 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools freezes - "restoring audio playlists"
Is this every legacy session you open?
Have you tried creating a new session and using import session data to bring the old sessions in? Maybe import only a few tracks at a time and see if it is any specific track that is causing it?
Are all your plugins up to date? This can cause problems if the sessions have an old plugin that's not up to date etc.
Or try loading the session hold down the shift key to open with plugins deactivated incase it is plugin related.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 09-23-2013, 08:30 AM
Thanks for your reply.
I have tried importing in to a session and I just tired the shift key, neither working for this issue.
Old 03-25-2014, 01:47 PM
ScottRobinson ScottRobinson is offline
Did you find any solution to this? Just started happening today and its happening on multiple different sessions. Importing all the tracks into a new sessions worked fine but I can't realistically do that all the time. Thanks!
Old 03-25-2014, 02:25 PM
I did find a solution. I had some early version Waves plugins that were loading with the songs that turned out to not be compatible with Pro Tools 10. When I deleted them from the plugins folder everything started working.
Old 05-13-2014, 03:03 PM
Do you have any idea why opening them with the Shift key didn't work?
Old 05-13-2014, 03:40 PM
No, it seems that they were just incompatible with Pro Tools 10. Some other programs automatically put plugins on a "blacklist" the second time you load up the program but Pro tools would just stop every time.
PT 10.3 Freezes When "Restoring Audio Playlists" ktuulu Windows 9 06-14-2016 09:57 PM
Pro Tools 10 HD freezes at "Restoring Controllers....Configuring EUCON" Mr. Light Artist Series 1 02-25-2016 10:42 AM
Pro Tools Crashes during "Restoring Tracks" portion of startup rhythmator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-28-2014 10:42 AM
Profire 610 + PT9.0.5 on HP DV7 Win7+64 "Crash" at Restoring Audio Settings **HELP** ozbirko Windows 2 09-14-2011 12:23 AM
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" bradykrzemien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-18-2009 09:18 AM
