Correct way to record with ADC on
OK, aside from the PT bug that is goind around about tracks being out of phase-
Is there a correct way to overdub tracks with ADC turned on? I may need ADC for other tracks that are playing back but can I theoretically record the new overdub with no inserts or sends on this new track and have it playback fine? running 6.9cs1 96i/o PT HD + prosess card G4 1.4 GHZ OS 10.3.8 1.5GB ram |
Re: Correct way to record with ADC on
bump...
I normally turn off ADC for tracking -- or if I have something with a large ADC value across the master fader... I'll disable ADC for the Master Fader (or disable the plug-ins across the Master Fader). When my largest ADC value is something less than 20 to 50 samples.. I don't normally worry about it (it should be taken care of by ADC).
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
I've never tracked with ADC on, nor would I ever consider it. If there are plugins that cause that much latency (like Waves Lin EQ and such) choose something else for tracking. I would hate to loose "feel" over anything else.
Schwabbl
Mac Pro, Pro Tools HDX, Orion 32 HD (2), Pure2 ADDA, Solaris DA www.schwabmusic.com |
Thank you.
How do you turn ADC off selectively per track? 'can't find it in the manual Seems I have to learn the hard way. I'm considering never upgrading PT again after this fiasco web page I never used ADC to track since I was tracking before mixing. But now that I am mixing/tracking I let that one slip - thinking pro tools wouldn't be buggy like that. |
In the Mix Window turn on the ADC view.
In Pro Tools the normal keystrokes/mouse combo to disable and reenable something is to Ctrl+Command click on it. In this case you'd Ctrl+Command click on the top ADC value displayed and it should turn gray. Rail
I frequently overdub while mixing with ADC enabled, and Pro Tools magically figures out where to place the newly recorded part in the timeline. While recording, I deactivate the plugins across the mix bus to minimize latency, then reactivate them after overdubbing. So far, all's well.
Michael James michaeljamesproducer.com www.IndieProMix.com System info: PT Ultimate 2019.6 HDX, Mac Pro 5,1 Westmere, OS 10.13.3, UAD2 Octo PCIe, 2x Lynx Aurora16 w LTHD cards, 1x Lynx Aurora(n) 32 ch analog I/O DigiLink, 4x Dangerous Convert-8 (AES via Lynx), Dangerous Convert-2 (AES via Lynx), Dangerous Vonvert AD+, Apogee Big Ben, SSD boot drive, external FW800 audio drives |
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
I actually keep ADC on all the time. When tracking and overdubbing. I don't put anything across the 2-bus until I start mixing. I also check the compensate for delay box in the I/O setup window. I have noticed the little artifacts at the end of audio files, but they only happen when you hit stop to end recording as opposed to punching out and then hitting stop. I hope that makes sense.
SLeiweke HD3, OS X 10.4, G5 Dual 2.3, 2 Gig Ram, PT 6.9
sleiweke 2019 Mac Pro Rack 3.3 GHz 12-Core 96 GB RAM OS12.6.3 HDX Pro Tools 2023.6 Lynx Aurora (n) 32 2 Avid S1's |
Read and Write drive are now playback and record is this correct | evilstudios | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-01-2014 10:53 AM |
Am I correct in saying... | nibbs | macOS | 2 | 12-12-2013 04:53 AM |
Please Correct Me.... | drumdandrum | Pro Tools 10 | 17 | 10-24-2011 05:55 PM |
using the correct P.C. | crother316 | Windows | 1 | 07-23-2011 08:59 PM |
Is this correct or not? | outfit | Pro Tools TDM Systems (Win) | 1 | 05-31-2002 10:50 AM |
