Heat on a 'freeze track'
Let's say you're using Heat on an audio track then you freeze that track.
What happen to Heat processing after a track freeze? Does it live on the frozen track or get disabled? |
Re: Heat on a 'freeze track'
Hi, The Heat processing is separate and gets applied Pre or Post inserts for each audio track, regardless of whether it's frozen or not, unless it's bypassed of course. Heat isn't included in the processing for the frozen track, but is applied to the frozen track the same as any other audio track.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
If you apply Heat to a frozen track...will it thaw?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Here's an interesting question. It might be an RTFM answer, but if you Freeze an Instrument track, can HEAT be applied to it?
Not if it's an Instrument track - Heat never applies!
PT 2024.3 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Studio M2 Max on Sonoma, 64GB RAM, 4 TB & 8 TB external SSD NVMe drives, Neve 1073OPX(2), Slate VSX, Focal Solo Be6, Roland V-Drums, DW drums, too many VIs and plug ins to mention. |
What about a "Thaw" plugin? Kinda melts the sound into liquid. But I guess it already exists. |
HEAT is a global warming plugin...
Microsoft Windows 11 Home 64-bit OEM DVD Avid OMNI PCIe Pro Tools Ultimate 2023.12 CPU: Intel Core i9-10980XE Motherboard: Gigabyte X299X AORUS MASTER E-ATX RAM: 64 GB Crucial Ballistix Sport LT DDR4 Screen card: MSI GeForce GTX 1660 VENTUS XS OC |
No global warming seen here in Philippines. Same weather every day of the year and locals say hasnt changed in their lifetime
Commit or Freeze with Heat (HDX) causes Pro Tools HD to hang | DetroitT | Pro Tools HDX & HD Native Systems (Mac) | 23 | 10-18-2017 02:51 PM |
Track Freeze & HEAT | sadateffendy | Pro Tools 12 | 1 | 03-15-2016 04:52 PM |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
Heat vs Master Track Plug In | SWSPHX | Pro Tools TDM Systems (Mac) | 1 | 08-20-2010 02:12 PM |
Track offset menu or track freeze as workaround for ADC? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-27-2008 12:19 PM |
