Old 03-28-2008, 11:25 AM
thibault thibault is offline
Default assertion error: how do you keep the digi databases deleted?
So I've just got my rig up and running (PT 7.3/003 factory console/desktop-XP pro) and whenever I open up protools a dialogue opens with an assertion error This occurs after protools has loaded and before I open a session (though when I click OK and open one everything runs smoothly). The general troubleshooting says to delete the volumes files in the digidesign databases but whenever I do and open pro-tools I get the same error, I check my drives and the files are there. Is there a way to remove those files entirely? Anyone know whats up and what else I'm not doing?
A new user...clearly.
processor:AMD opteron 2216 2.4GHz dualcore (x2)
motherboard:Asus KFN5-D SLI
chipset: nVidia nForce Professional 3600
RAM: 4 gigs kingston DDRII
drives: 2 dedicated 500GB Seagate SATAII (7200RPM) and 160GB seagate SATAII (system)
Windows XP professional
Pro-Tools 7.4cs5
003 Factory
Old 03-28-2008, 11:39 AM
spkguitar's Avatar
Default Re: assertion error: how do you keep the digi databases dele
No. Those files are created, used, and needed by the program. The only reason why it is recommended to delete them is that occasionally they can become corrupted. If you delete the corrupted file, Pro Tools creates a new, fresh working one when it starts up.
Deleting preferences and databases is definitely not a cure-all, and most likely is not related to your problem at all.
Could you post the exact error message that you are getting? Could you post your system specs as recommended at the end of the General Troubleshooting thread? That would enable us to help you more accurately.
Old 03-28-2008, 01:20 PM
PT version 7.3 (haven't gotten any CS upgrades or installed 7.4 as of yet, 003 factory/console, 2 AMD opteron dualcore 2216 SKT (hotfix is taken care of), ASUS DL OPT 2000 series (KFN5-D SLI) NV3600 ECC/DDR2, Kingston PC2-5300 667MHZ ECC (4gigs), 3 seagate drives (2 500GB sataII 32mb/system 160GB sataII 8mb)
"Assertion in "\code\azuki_Cliff\AlturaPorts\NewFileLibs\Sys\Sys _line 144"
is what shows up. Thanks.
Pro-Tools 7.4cs5
003 Factory
Old 03-28-2008, 03:00 PM
spkguitar's Avatar
That problem was fixed in a CS update. It's honestly harmless; it happens when you have the network card turned off.
I would definitely recommend getting the latest cs update for your version at the very least. Not only will it correct that error, but it will fix a slew of much more nasty problems that you haven't come across yet.
Old 03-28-2008, 03:44 PM
The Weed's Avatar
The Weed The Weed is offline
Get to 7.3.1cs6, the last so far before 7.4.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
assertion error - delete databases, far too often- WHY? Dustin Mosley Pro Tools TDM Systems (Mac) 4 12-09-2007 08:17 PM
volume databases can not be deleted breakie Pro Tools TDM Systems (Mac) 1 11-08-2006 04:09 PM
volume databases can not be deleted breakie Pro Tools TDM Systems (Win) 0 11-08-2006 02:58 PM
uninstall deleted ALL MY DATABASES!!! xda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 01-16-2006 01:55 AM
Assertion Error in 6.4 (Digi 002) David Penick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-13-2004 06:01 PM
