Converting from 96kHz/24bit to 44.1kHz/16bit
I recorded and mixed at 96kHz/24bit; now I have to convert to 44.1kHz/16bit. I used POW-R Dither (16bit) in the master fader and I bounced it (44.1kHz/16bit) but some strange noises appeared. Suggestions? Thank you very much! Here my specs: Pro Tools LE 8.0.4 with a 003 Rack Computer Model : Sony VPCF12S1E Workgroup : WORKGROUP Host Name : pro_tools User : x Processor Model : Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz Speed : 1.86GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Sony VAIO BIOS : AMI R1110Y6 05/31/2010 Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DDR3 SO-DIMM Chipset Model : Sony Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Sony Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 6GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMT351S6BFR8C-H9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Elpida EBJ21UE8BDS0-DJ-F 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA GeForce GT 330M (32 SM4.1 1.26GHz, 1GB DDR3, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GT 330M (48SP 6C 1.26GHz, 986.6MB) CUDA Processor : NVIDIA GeForce GT 330M (48SP 6C 1.26GHz, 986.6MB) Compute Shader Processor : NVIDIA GeForce GT 330M (32SP 1.26GHz, 986.6MB) Storage Devices Seagate ST9500420AS (500.1GB, SATA150, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (E:) Optiarc BD ROM BC-5500H (SATA150, BD-R, DVD+-RW, CD-RW, 8MB Cache) : N/A (D:) Logical Storage Devices Pro_Tools (E:) : 106GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA150, 2.5", 7200rpm, NCQ, 16MB Cache) Win_7 (C:) : 360GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA150, 2.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (D:) : N/A @ Optiarc BD ROM BC-5500H (SATA150, BD-R, DVD+-RW, CD-RW, 8MB Cache) Peripherals LPC Hub Controller 1 : Sony PM55 LPC Interface Controller Audio Device : Sony P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : Sony High Definition Audio Controller Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Disk Controller : Sony P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : Sony PCIe SD/MMC Host Controller Disk Controller : Sony PCIe SD/MMC Host Controller USB Controller 1 : Sony P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Sony P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Sony E832h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Controller Gigabit Ethernet PCI-E generico Marvell Yukon 88E8057 Wireless Adapter 1 : Intel(R) Centrino(R) Advanced-N 6200 AGN (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: Converting from 96kHz/24bit to 44.1kHz/16bit
If it were me, I would do both these steps separately instead of together at the same time, and I would not do it to a track that had the final limiting applied.
I would print the mix without L2007, Precision Limiter, L1, L2 or L3 squeezing the last few dB out. I would then SRC export the mix as 44.1/24. I would bring this file into a new 44.1/24 session where final limiting would be applied with a ceiling of (-.2) with dithering and then export as 44.1/16. Beware though that exporting from 24 to 16 in PT automatically applies dithering so exporting with Pow-R at 16 bits in a 24-bit file and truncating with another program or bringing this directly into your burning software would be appropriate.
Thank you very much! |
Remove both...
When sample-rate converting, peaks above those in the source can be created. It's best not to SRC a file that's been strongly limited to 0 dBFS, and it's also not advisable to add dither to a file that has been limited to 0 dBFS.
The problem may be as simple as the ceiling you have set on Maxim. If you have the ceiling set at 0 dBFS, try reducing it a little. -.2 dBFS is popularly recommended by Bob Katz.
Maxim can noise-shape the dither, but POW-R is well known to have some of the best noise-shaping curves around. There's no reason you can't use the dither function on Maxim, but if you're obsessive/compulsive, then by all means go with the POW-R.
But, if you're O/C about using POW-R, then you really should be applying it after the sample-rate conversion not before. Bounce the mix out at 44.1/24 without limiting. Bring into new 44.1/24 session. Apply limiting, dither and bounce out at 16.
I've just discovered a funny thing about noises: you can hear them only with VLC, the mix works perfectly with Quick Time or Windows Media Player. Ah I did not mention that I created a multiband compressor with 4 aux tracks. Should I apply it at the final stage too? Thank you for your precious suggestions! |
24bit 96KHz vs 16bit 44KHz sessions | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-03-2008 08:59 AM |
16bit vs 24bit | TwinSnakes007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-14-2008 06:39 PM |
CHANGING A SESSION FROM 96KHZ TO 44.1KHZ | MLK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-11-2004 03:54 PM |
Converting 44.1khz .wav's to 22.1khz MP3's | bruceup | Pro Tools TDM Systems (Mac) | 1 | 09-04-2003 07:02 AM |
HD benefit for 16bit 44.1kHz musicCD | andyo | Pro Tools TDM Systems (Mac) | 1 | 01-19-2002 12:54 AM |
