Old 07-25-2019, 08:30 AM
Raoul23 Raoul23 is offline
Default C24 preamp routing help?!?
Hello people I’m looking for some help and understanding on how to hook my 1176 to my c24 pre’s
At the moment I have a behringer patch bay with rows 1-8 used for monitoring through the c24 and kempers being plugged in etc. Yesterday I purchased a warm audio 1176 because the price was to cheap to say no to.
How would I connect this to the pres on the c24 using my patch bay??
My thinking was db25 to jack connected to bottom row 9-16 on patch bay then jacks connected to top of patch bay 9-16 to db25 input on 192. Where would I connect the 1176.
Hope I have made sense
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 07-25-2019, 10:02 AM
henningaround henningaround is offline
Default Re: C24 preamp routing help?!?
Hello!
Afaik the C24 has Inserts for the MicPres also on DB25 connectors. I guess one would wire those to a patchbay as well as the I/O of the 1176 and insert it that way!
Old 07-25-2019, 11:32 AM
What I can’t get my head around is if the pres are connected to the patch bay how do I connect the mic to the pre ???
Raoul Crane
Old 07-25-2019, 12:15 PM
DB-25 to XLR(male) and use an XLR panel is one way(and how my friend does his C24 setup). I have mixed feelings on having mic lines on TRS or TT because every time you plug or unplug a connection with phantom power turned on, it momentarily shorts and can cause loud pops if you have active inputs in your session. My preference is to leave mic connections out of the bay. Then, route the line OUTPUTS of the preamps to the bay(top row) and normal to the bottom row to feed interfaces. That way, you can do nothing, OR patch out and back from outboard(compressors, limiters, Pultecs, etc).
Old 07-25-2019, 12:29 PM
I’m still confused @albee ?? Where would I plug my mic ??
C24 pres 9-16 to top row of patch bay, then bottom row to ins 9-16 on 192?? But where do I connect mic
Raoul Crane
Old 07-25-2019, 12:42 PM
Right think I might have it!!
XLR Panel => mic in 1-8 on c24
Line out 1-8 on c24 => bottom row of patchbay 1-8
Top row 1-8 patch bay => analog in on 192
Raoul Crane
Old 07-25-2019, 01:22 PM
In a say "studio environment" you would wire your stage box or wall box also to that patch bay to connect them to the micpres. You should take into consideration that you need a lot of patchbay real to to wire a 16 out wall box and its returns, a C24 with 16 micpres and their inserts and a 192 IO not to mention any outboard, the monitor controller of thr C24.... And the list goes on. That's why people use bantam patchbays for such big I/O counts.
Old 07-25-2019, 01:26 PM
Btw if you really want to connect your whole studio to a patchbay you can find used ones with DB25 connectors on the back. So you don't need all the breakouts.
Old 07-26-2019, 03:24 PM
This works, but my choice would be line outs to the TOP row and 192 inputs on the bottom row. Most folks set patch bays so that signal flow is "downhill"(outputs above inputs) Of course, if this makes more sense for you, go with it(but do label properly)
Old 07-26-2019, 03:26 PM
True, but patch bays CAN be a source of misery if not well-cared for. Try to buy new if possible. The Redco 96 point with DB25 connectors is $499 at banjo center
Using outboard Preamp/Bypassing Mbox2 Preamp KennyC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-10-2007 12:00 PM
Studio Projects VTB1 preamp vs ART TPS-II preamp?? ESR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-28-2004 09:23 PM
I'm torn.. Digi001 with better preamp or Digi002 with cheaper preamp/future upgrade Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-05-2003 11:22 PM
Routing a Mono PreAmp. OgnKog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2001 01:37 PM
preamp routing crushed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-25-2001 09:42 AM
