Old 03-07-2012, 01:51 PM
philip morris philip morris is offline
Default Loop Playback Tips
logic user here new to PT, i work a lot setting loop regions and am having trouble with the PT workflow.
i've set dynamic transport & loop playback, but it's the selection of the loop region i find a bit clumsy.. if you are zoomed in just a little, selecting a region doesn't snap to bars, the precision seems infinite making a quick perfect 4 bar loop selection a drag as it's always a bit off, and there seems to be no way to modify the start/end points of the selected region so you need to re-start until you get it right... frustrating to say the least but perhaps i'm missing a faster approach?
Old 03-07-2012, 02:33 PM
Pena P Pena P is offline
Default Re: Loop Playback Tips
Are you in grid mode?
imac 10.6.6 intel core i3 4gb
Pro Tools LE 8 w/ Mbox 2 mini
STUDIOPHILE AV40 monitors
Old 03-07-2012, 02:39 PM
yes
Old 03-07-2012, 02:57 PM
zedhed's Avatar
zedhed zedhed is offline
If you are in grid mode then obviously the selection will snap to grid. If the loops start/end are sitting slightly out of the bar , the tempo must be out of sync with what the loop was recorded at.
Try different tempos and compare the loop on the grid as it changes. Bare in mind you can set the grid to 1/2, 1/4, 1/8, 1/16 note etc too.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-07-2012, 03:39 PM
i'm in grid mode but the selection is not snapping to grid, the tempo of the loop is perfect and that isn't the problem i just can't get the selection to snap so i must be doing something wrong?!
i'm using the grabber tool, i'm in the upmost section where the bar numbers are indicated, i hold click on say bar 2, move the mouse till bar 4 (the red line follows my move) and if i stop just a millimeter after "4" the selected part will be from bar 2 to bar 4|1 or wherever, it just doesn't snap to the bar unless i'm super zoomed out, only then will it snap (but i like working zoomed in)
btw changing the grid to 1/16, 1/8 etc only changes the grid spacing not the snapping of the selection which remains infinite, hope that is clear!
Old 03-07-2012, 03:53 PM
zedhed's Avatar
I'm on PT9 and it works both zoomed in or out. I'll leave it to another PT10 user to comment. Good luck.
Yes that was an aside mention.
HD 96I/O
Old 03-07-2012, 05:17 PM
The Weed's Avatar
The Weed The Weed is offline
Are you in Absolute or Relative Grid Mode?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-07-2012, 05:31 PM
absolute i think, i just tried clicking the blue "grid" and it became purple "rel grid" but still no snapping to grid
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
loop playback? fredrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-19-2005 01:31 PM
Loop playback in PT LE d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-04-2003 06:38 PM
Drum Loop Tips in Producing/Arranging fmckinnon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2001 02:13 PM
