Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 09-13-2017, 11:02 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default MKaster Fader input
how can I know the level of all my combined tracks going into the Master Fader.The Master fader volume level in the meter is post fader.How can I see the pre fader input volume hitting that master channel ...Thanks
Old 09-19-2017, 11:18 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: MKaster Fader input
You can put a compressor/limiter on the first insert of the master fader and see what the levels are in the plugin.
Will
System Details
Old 09-19-2017, 12:45 PM
That, or put your master fader at -0 and see the real level Having said that, what I do is insert an EQ plugin(FabFilter ProQ 2 here) and keep it on the screen at all times(I run 3 screens here). Its set for a steep hi-pass, but also shows a spectral display and has nice metering on it As you learn more, you will likely come to realize(as I have) that its really easy to hit the master too hard. My new solution is to insert the TRIM plugin on all AUDIO and INSTRUMENT tracks with a -10 setting. As soon as I finish tracking(when slamming the master is not so important), I enable all the TRIM plugins(they are in my session templates but bypassed) and that usually solves any master clipping
Old 09-19-2017, 08:17 PM
mikeyman's Avatar
well I been trying to figure this out and i'm not going to get all hung up on it as long as I don't hear distortion I guess i'm doing good.I have been recording in the green and things have been going good.
When you raise the master fader it raises the level in the channel as far as I can see...Ill post the video that got me thinking about this so you guys can check out if you want to set up like this guy.Not sure if he has it right either
Old 09-19-2017, 08:21 PM
mikeyman's Avatar
https://www.youtube.com/watch?v=zsN9FouyZIc
Old 09-20-2017, 03:43 PM
mikeyman's Avatar
maybe the best way to check is create a stereo audio track put it in record and run all the channels to it and turn on pre fader mode
Old 09-24-2017, 02:04 PM
Dan IceWood Dan IceWood is offline
go to the options menu and simply select "pre fade metering".
PT 9 No Input to my Master Fader I/O settings? mij sang macOS 0 03-22-2011 03:46 PM
Mixer fader and input level Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-23-2010 07:43 PM
Name at input fader display kalunga VENUE Live Sound Systems 4 11-23-2007 08:18 AM
Aux input vs Master fader taylor4814 Pro Tools TDM Systems (Mac) 2 08-28-2003 11:40 AM
keyboard input for fader control ? clam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-01-2002 07:13 PM
