CPU Spiking and Stopping Pro Tools
I've been having issues where I am working on a session, and the task manager shows that I'm in the 40% range of CPU usage. Suddenly, Pro Tools will spike, and give me the 'Pro Tools ran out of CPU power' message. I disabled turbo boost, and I went into the task manager and didn't allow Pro Tools to use the last CPU core or the last two CPU cores. These things did not work.
I'm on Windows 10 using an Intel i7-6700 CPU. I've also got 16 GB of ram. My buffer setting was increased to 1024 (the max I could go to with my Focusrite Scarlet 2i2). Any ideas here? Thanks in advance! |
Re: CPU Spiking and Stopping Pro Tools
Run on a supported software+pro tools+plugin configuration. Run with a larger IO buffer, check plugins are up to date, remove plugins in batches etc. to try to sort out which plugins are causing this, print or freeze VI tracks too reduce load (freeze requires you upgrade to Pro Tools 12). Is the computer fully optimized? *Every* last thing done? (I would bet it is not). Post a Sandra report....
If you are having a bunch of related issues it would be better to keep them in one thread. It's a waste of everybody's time going over stuff already covered. |
Figured it out. This plugin was the problem:
https://www.waves.com/plugins/scheps...llel-particles Once removed, everything went back to normal. |
Yeah, it was super weird. I didn't have a big session and certainly had the CPU headroom, but PT would randomly spike and stop. I took the plugin off and everything went back to normal!
Pro Tools 11 HD Lag when recording and stopping | asaffulks | Pro Tools 11 | 8 | 08-07-2015 10:24 PM |
Stopping Pro Tools opening all MIDI ports | c.c. | Windows | 4 | 11-05-2013 07:43 AM |
Starting and Stopping Pro Tools from Venue | Scott Fahy | VENUE Live Sound Systems | 4 | 02-14-2012 12:43 PM |
Itunes 7.4.1 update stopping Pro tools from opening | martyk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-21-2007 05:00 PM |
DIGIDESIGN-Pro tools stopping at 33 minutes | sean shannon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 28 | 04-07-2003 05:25 AM |
