Old 12-05-2011, 12:55 AM
halifaxer12 halifaxer12 is offline
Default Pro Tools Midi Issue
I'm having an issue in PT where I play the notes I want from a synth using my controller, but when I actually hit play/record on the track in PT the notes sound completely different or out of key. When I play a sequence of notes using a sound from Reason, for example, without pressing play in PT, it sounds like a different key compared to when I press play or record. Does anyone know what the issue might be? I have a set of synth chords that I want to repeat later in the song but the duplicated track sounds different (another key) than the original track...
Hardware:
M-Audio KeyRig 49
Pro Tools 8 MP
Windows 7 64 Bit
M-Audio Fasttrack USB
Reason 6
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Fix for 003/002 MIDI Issue with Pro Tools 9.0.1 Avid Technical Alerts 1 01-24-2011 09:36 PM
Pro Tools LE MIDI Issue charlescbullock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-15-2010 05:04 PM
Pro Tools 8 MIDI issue [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2009 12:36 AM
Pro Tools 7 Midi Issue batchmister1 MIDI 1 12-23-2005 10:15 AM
