Export or Bounce to BWF-p?
I've been wrestling with PT10 all morning attempting to export 8 mono tracks to a SINGLE BWF(poly) track. Is this even possible in PT, I keep getting multiple .wavs out?
Re: Export or Bounce to BWF-p?
You must add the correct file suffix. For channel one you must end the file .A1.wav for channel two .A2.wav etc....
It will then show a polywav in the clip list. Then export file as interleaved and you are done.
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
This is what I'm trying, still no luck... I am able to import them all into Audacity and export it as a bwf properly. I'd like to avoid this since it takes an unnecessary amount of time. |
Thats because of the staggered clips!! They all need to have the same length and start position.
... maybe by marking the first and last clip with object tool and consolidating.
That keeps the relevant audio parts in its staggered order.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Try that, but don't forget to add the suffixes.
that's correct, but after adding the suffixes A1, A2, A3 ... to the file and having exported it, if we re-import the resulting file, the suffixes are .L, .C, .R ...
We must then re-edit the suffixes in this file. Pfff ... |
Can PT9 Bounce/Export to BWF? | StinkyStan | Pro Tools 9 | 1 | 07-07-2011 06:30 PM |
Bounce to disk vs export | osroubek | macOS | 8 | 02-04-2011 03:46 PM |
Bounce or export?? | sebisuarez | General Discussion | 0 | 12-23-2008 03:57 PM |
Bounce or export? dithering? | sebisuarez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-26-2007 01:41 AM |
Export, bounce, consolidate? | Holly73 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-29-2005 10:43 AM |
