Installation issues with Pro Tools 10.3.10
I have tried to fix the bugs I am experiencing with Pro Tools 10.3.9 by downloading version 10.3.10 but it won't install. I keep getting this message. Can anyone advise.
Pro Tools cannot be installed because the following error(s) were found on your system: - An incompatible version of the OS was found. Pro Tools 10.3.10 requires Mac OS X version 10.7 or higher. |
Re: Installation issues with Pro Tools 10.3.10
Is your os 10.7.x (Lion) or above? Chris
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.4 running Protools 2024.3 Mac Studio M1Max - 64GB MacOS 14.3.1 running Protools 2024.3 |
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) Last edited by Chief Technician; 03-30-2015 at 04:35 PM. Reason: quote syntax |
I'm at 10.14.4 and I'm getting the same message that its incompatible unless its 10.7 or higher
You have but one option depending on how old your Mac is and what was the original OSX when that model was introduced. IOW if your model Mac first came out when OSX 10.9.5 was what Apple was putting out you could roll back to that. However if it's newer than that - say it was introduced when Apple was shipping Macs with later OSX versions then your only other option is to get current with PT 2019 and replace/upgrade all those old 32 bit plugins (keep in mind that RTAS was last supported in PT10). |
Pro Tools 10 Installation Issues | JamieOxford | macOS | 7 | 10-25-2011 07:35 AM |
Pro Tools Developer and MBox 2 Drivers installation issues | dilig0 | Virtual Instruments | 0 | 11-10-2010 12:42 AM |
Pro Tools LE Version 7.3 - Installation Issues | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-27-2009 05:43 AM |
pro tools installation causes garageband/logic issues | chris4peeps | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-15-2008 06:51 PM |
Interlok Issues, Installation Issues? | TONECHILD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-02-2007 06:23 AM |
