Griffin g4Port or GeeThree StealthPort?
I did a search on the DUC, but couldn't find a definitive answer on this. We're looking at updating a couple of Mac G4s (one Silver and one new-model dual) with a serial adapter. Just wondering if there are any significant differences between the Griffin Technology G4Port and the GeeThree StealthPort.
Additionally, it looks like the StealthPort requires the use of one of the PCI slots in order to mount it in one of the new dual G4 models. If I remember correctly, you used to be able to just mount it in place of the modem. Is this true? Is there a work-around? Does the G4Port still allow you to mount it into the modem port? If so, that would seem to be an advantage, so as to not take up a PCI slot. Thanks, Noel |
Re: Griffin g4Port or GeeThree StealthPort?
For what it's worth, my Griffin G4 port works flawlessly in my G4/933, and you don't need to waste a PCI slot.
Hiya Noel,
The same applies to the g-port as to the stealth in the new macs. At the moment i am considering drilling a hole in the grille at the back of a dual 867, to put the cable through! as i do not have a spare PCI slot (HD3 & SCSI). The trick to making the hole as small as possible seems to be to carefully remove the cable from the card and then pass the cable through the hole made, and reattach the cable to the card in side the mac. [img]images/icons/shocked.gif[/img]
RetroBoy Don't forget about the music |
yah, Griffin's tech support response is to "use the PCI slot bracket as the modem port cannot be removed." but it can. I managed to take it out (yes, heat sink has to come out, too) and feed the g4Port wire thru the hole where it sorta dangles loosely. it *just* reaches. Maybe if enough people email [email protected] they might work on a new bracket?
what they *ought* to do is make their g4port so that it uses the modem port wire inside the mac, then provide an RJ-11 to 8-pin mini-DIN adaptor for the outside. That way, no matter where apple moves the modem on each new model, they can hook up a serial port. [img]images/icons/rolleyes.gif[/img] bah. e. |
Griffin g4Port stable in 001 & PTLE 6.4-OSX 10.3? | JoeM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-26-2005 09:00 AM |
Griffin G4Port serial MIDI interface on OSX PT? | knewbee | Pro Tools TDM Systems (Mac) | 4 | 04-22-2005 07:38 PM |
Griffin G4Port supported in OS X? | 1150Post | Post - Surround - Video | 4 | 11-11-2003 04:58 PM |
What's prefered for G4 serial MIDI:GeeThree Stealth Port or Griffin g4Port ? | JoeM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-22-2002 08:31 AM |
G4/GeeThree Stealthport/MOTU Serial MIDIExpress XT - PROBLEMS!!!! | VanEdge | MIDI | 8 | 02-16-2001 06:26 AM |
