Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 01-23-2018, 11:50 AM
Philharmonic7 Philharmonic7 is offline
Default Dante AVIO Adapters
Hello folks,
Just saw this release from Audinate,
https://www.audinate.com/products/de...io?lang=es#usb
Nifty device I must say. I was thinking would this be possible (USB version) to finally enable AoIP or AVB to Windows for the S3? No information has been released from Avid nor Audinate regarding integration and compatibility. Still, I thought this was potentially interesting.
Old 01-23-2018, 05:08 PM
EddieJones's Avatar
Default Re: Dante AVIO Adapters
I dont think this is AVB compatible
Old 01-23-2018, 07:30 PM
Ahh shucks!
Old 01-23-2018, 07:57 PM
EddieJones's Avatar
I still need to get one of these and test but they are expensive https://echoavb.com/products/streamware-nic-1
Old 01-24-2018, 10:27 PM
I'd figure Avid will compensate you for that. That's lame if they don't. I mean they should for your active involvement here in the forums. Just my two cents
Old 01-25-2018, 07:00 AM
EddieJones's Avatar
They do...I'm the Product Manager for all Control Surfaces ;-)
Old 01-25-2018, 11:24 AM
BScout BScout is offline
Interesting product (the other versions, not the USB in this case.) Could put an S3 on a Dante network using the analogue in version and an analogue out version connected to the S3's analogue i/o. Don't know if it would be worth the hassle with the limited specs (or the cost)
I wonder if the USB version has any of the Dante accelerator chips on board. Latency from a standard ethernet port is still an issue for laptops whereas you can use one of the PCIe accelerators on desktop towers.
'eNAMMoured' © - Synths/Dante AVIO adapters/UA Arrow & Ox Amp Top Box unkJE General Discussion 0 01-19-2018 08:28 AM
Virtual Dante I/O tlinget Third Party Interfaces 2 01-17-2018 03:26 PM
Mix Rack to Dante? Matthew Steel VENUE Live Sound Systems 7 05-05-2016 05:54 AM
HD Native and Dante JCBigler Pro Tools HDX & HD Native Systems (Win) 11 12-10-2013 01:01 AM
Protool 9 with Dante JCBigler Pro Tools 9 3 09-05-2011 07:43 PM
