Old 01-10-2018, 08:55 PM
Andresen Andresen is offline
Default Addictive Drums 2 No sound on playback.
I'm only a couple days all and all maybe 12 hours into PT12 Full.
Am I missing a step here? I'm doing nothing different from my old daw.
I setup an AD2 track in a new project.
Select my kit, drag a beat clip to the track, set loop length.
It plays fine. Save and exit Pro Tools.
Reload ProTools and the project, Everything looks ok but the beat clip midi data in unresponsive.
Any ideas?
Old 01-11-2018, 12:03 AM
Stig Eliassen's Avatar
Default Re: Addictive Drums 2 No sound on playback.
Is the clip greyed out? Check if the MIDI connection to AD2 is active.
Old 01-11-2018, 06:29 AM
Hello,
So how does one check if AD2 is connected to the midi data?
yes, the data is dark grey.
Thanks for the reply!
Old 01-11-2018, 07:03 AM
View (menu) > Mix window views > Instruments. Make sure that is checked. Then, on the instrument track at the very top, check that the MIDI output is routed to AD2.
Also, make sure that you haven't accidentally muted the MIDI clip(s).
Old 01-11-2018, 07:35 AM
Thanks for the help!
So what I'm seeing is that AD2 needs to be assigned to a channel as if it were an external sound module. Is that about right?
Old 01-11-2018, 09:08 AM
Yes, that is correct. You should see something like Addictive Drums > Channel 1 for the MIDI routing.
Old 01-11-2018, 10:41 AM
I had set it manually, but yea! Thanks for the help!
Old 02-16-2018, 02:39 PM
randb1 randb1 is offline
I was having the same problem, and your answer fixed it for me, but I'm curious, is this something new with Pro Tools 2018? I don't ever remember having to do this in previous versions of it. The interesting thing is when I first create the inst. track and assign a VI to it, i.e. Superior Drummer 3, the track plays fine. It's only after I instantiate a new "recall preset" to that track. Then when closing and re-opening the song that track is grayed out and I find now that I have to apply your solution to "wake" the track up. Is this correct?
Thanks!
Problem: Recording Electric Drums via Midi with Addictive Drums (Latency problem) Don Bravo General Discussion 5 07-04-2014 11:49 PM
Addictive Drums RTAS instrument plugin much softer when drums are "individualized" jglunt2112 RTAS & TDM Plug-ins 7 12-05-2013 06:54 PM
Addictive Drums - No Sound piwacquet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2011 09:17 AM
Need a sound replacer to use with addictive drums progtools Tips & Tricks 5 12-11-2010 10:09 AM
addictive drums, drums replacement ericlees Tips & Tricks 2 09-28-2010 10:58 PM
