Old 07-27-2007, 08:01 PM
CalebB CalebB is offline
Default 003 zero latency; Mix/Playback?
Does the 003 rack allow me to directly monitor my inputs as they come in to the box like the M-Box?
I'd like to upgrade from the original M-Box but my G5 doesn't run well with smaller then 1024 buffer sizes, which I have lived with because of the direct monitor feature.
Also, why does PTLE 7.3.1cs2 crash all the time for me?
G5 Power Mac PPC
2.0 Ghz dual
4.5 GB RAM
OS 10.4.9
Old 07-28-2007, 03:55 AM
The Dougfather The Dougfather is offline
Default Re: 003 zero latency; Mix/Playback?
No it doesn't, i find this frustrating coming from an Mbox, it's software monitoring all the way, so you either have to have aux inputs or record enabled tracks to get audio throughput.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 07-28-2007, 07:46 AM
tele_player tele_player is offline
Use Low Latency Monitoring. It's not quite the same as software monitoring, as the monitored signal doesn't make the trip through the computer - monitoring is done in the interface.
Quad 2.5 G5, 4.5G RAM
Old 07-28-2007, 08:23 AM
Thank you both.
I have heard of low latency monitoring, but I don't know what that is. Anybody want to shed some light on that for me?
Is this feature of low latency monitoring taxing on the CPU?
G5 Tower PPC
2.0 Ghz dual
4.5 GB RAM
10.4.9
PTLE 7.3.1cs2
Old 07-28-2007, 08:39 AM
gar_lei gar_lei is offline
Hello
I have a Digi002 and I'm experiencing the same problem while monitoring... Latency...
I used M-Powered Protools before and M-Audio had a little software that allows me direct monitoring.
And I couldn't find that with my Digi002.
So where can I find Low Latency Monitoring?
Thanks in advance!
Old 07-29-2007, 10:44 AM
People, look in the manual for Low Latency Monitoring. It's a feature of Digi 001, 002, 003 and Mbox 2 PRO, and it's exactly what you're looking for. It's more convenient than the (cheaper to implement) mixer found on the Mbox, and it achieves lower latency than the smallest buffer size in ProTools LE.
Old 07-29-2007, 10:51 AM
Low latency monitoring will give you a low latency input signal but it still won't let you monitor your inputs without a track being record enabled or an aux input assigned. I find this really irritating when im just scratching down ideas with my POD and i can't hear the guitar unless i have one of the above activated.
Cheers
iCON Photography
Old 07-29-2007, 10:58 AM
Yes, that's true. When I was using digi 002, I just kep my buffer at 128 or below, and rarely used low latency monitoring, since I was using Amplitube.
Old 07-30-2007, 03:13 PM
kRokksOn kRokksOn is offline
Cheers
You enable low latency mode in the options menu (at the bottom, says low latency monitoring).
And to hear your intput while playing back without having to record, keep your inputs as auto input monitoring, press alt+k to switch between track and auto input monitor.
"Ok I promise, this is the last plugin I´ll buy!"
www.syrland.is
www.sturluson-music.com
PT 9 and QT playback latency tokolosh Post - Surround - Video 2 11-27-2010 04:40 PM
Playback latency when using VIDEO koka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-14-2010 01:26 PM
Playback Latency Art Disco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-10-2008 08:16 AM
latency on playback. why?? dobryden2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-17-2007 08:46 AM
latency on playback?? dj_czech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-30-2001 04:24 AM
