Old 03-29-2021, 12:15 PM
spoons's Avatar
spoons spoons is offline
Default 2021.3 Video engine and bounce to .mov crashes.
Had a lot of video engine crashes today on sessions I’ve been working on for a while so I know they ran well in the last version.
Can’t seem to bounce a mix either to .mov without it crashing just after it’s bounced the audio.
Moved back to 2020.12 and all fine.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 04-23-2021, 03:07 AM
hobphin hobphin is offline
Default Re: 2021.3 Video engine and bounce to .mov crashes.
I'm having exactly the same issue - everytime I bounce any format of video the software hangs at the end of the bounce. temp audio files seem to be made in the destination folder but nothing else. really annoying as I should be bouncing cues all day long! :-(
Old 04-23-2021, 04:08 AM
OK - I've downloaded 2020.12.1 and installed that - problem solved so it's definitely a bug in 2021 software
Old 04-23-2021, 09:12 AM
SomeOtherGuy SomeOtherGuy is offline
Yep, I can't bounce to mov either with this version. PT hangs and I have to force quit.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 04-23-2021, 11:29 AM
nebosphere nebosphere is offline
I’ve had this problem and was able to get it to work by changing the bounce length. Are you bouncing to the exact length of your video?
Old 04-23-2021, 12:19 PM
tomguest.tv tomguest.tv is offline
I have this issue as well with 2021.3.1
Old 04-23-2021, 12:41 PM
gives's Avatar
gives gives is offline
Just saw this post and tried it here since I had not been in movie mode lately, but was starting today.. I bounced to Movie with no problem here and it's a large 96khz session. I don't usually work at 96khz when doing film work much now, but it was an older session and it worked just fine in realtime btw.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 04-23-2021, 03:32 PM
My movie length is 90 minutes, and I'm trying to bounce 2 minute clips as I've done for years. Doesn't work here...
Old 04-23-2021, 07:21 PM
gives's Avatar
NOTE THIS:
Don’t use Pad to Frame boundaries. It’s literally only necessary if you are going between Pro Tools and Media Composer or another NLE that is frame-accurate vs sample accurate. THIS caused me to crash until I figured this one out on the Movie Bouncing..
The 3rd Option: Directory should be global and sticky:
Session Folder: Defaults to Bounce Files subdirectory in current working session.
Prompt – on clicking Bounce will prompt for a location and is also sticky regarding the last directory tree.
Directory: Global and sticky. Not session based but rather global.
I would highly recommend checking out the 1-5 chicklets or Presets which are super handy for immediately switching between formats and paths on a click.
Use CMD + (number) click to program a chicklet macro. Set all of the attributes first.
Old 04-24-2021, 03:57 PM
Thanks--
As I'm not a film editor, I'm not using Media Composer...
Also have not been using the Pad to Frame option.
Are you saying the directory where the bounces go makes a difference?
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
PT 12.5.2 Video Engine crashes with more than 12GB of RAM tigas Post - Surround - Video 0 09-21-2017 09:58 AM
Video Engine Crashes: Uninstall DX and Codecs? notedmusic Pro Tools 11 2 10-10-2014 12:25 PM
