Question about Instrument/Midi track(s)
So, from what i understand, when you insert a new instrument track (lets say Massive), you must also insert a Midi track and route the Midi track to the instrument track, correct?
If this is the case, is there a way around this? For example, is there a "shortcut" for inserting a new instrument track that automatically inserts the Midi track as well? Excuse my "ignorance" as im coming from Logic 8, where all you needed to do was insert a new instrument track, load in your instrument (again, Massive) and just hit record and play away on the "virtual keyboard" (the caps lock key) or play on your controller keyboard (i usually use my Roland JP8000 as mine). Thanks for any clarifications!! -Sin |
Re: Question about Instrument/Midi track(s)
Prior to Pro Tools 7.x only MIDI/AUX tracks were supported whether instantiating a computer-based instrument or a hardware-based instrument. Pro Tools 7.x implemented an Instrument track, combining both a MIDI track and an AUX track (audio thru). Instrument tracks are best suited for instantiating Virtual Instruments, for instance, NI Massive. However when routing hardware-based instruments, Instrument tracks didn't work as intended so thee old method of using MIDI/AUX track combinations is still favorable. So, an Instrument track can record a MIDI performance and route audio thru. What an Instrument track cannot do is record audio. Bus Record is required to record audio.
Aaron Mulqueen - 001 HD Native |
Thanks!!! -Sin |
No, I don't think you got what I said otherwise you would not be asking the same question. Instrument tracks record MIDI and pass audio generally for computer-based instruments. If an Instrument track records MIDI why would you require a MIDI track in the case discussed?
i appreciate the help! i feel im getting a better hang of PT9 now!! thanks again!! -Sin |
...and welcome to the DUC.
http://www.youtube.com/watch?v=C4pKJabjxNs that was the very first one i watched and i dont think he mentioned that. and, thank you! :) im sure ill be posting on here alot as i go along and learn my way around PT9. -Sin |
Basically, Protools Instrument tracks work exactly like Logic Instrument tracks.
You create one, insert a VI, press record, and it records your midi info, and allows you to hear your VI. You can then later on switch out the VI for a different one, and the same recorded midi info will now play that one. However, to record it to an audio track, it will not bounce in place like Logic. You must bus the output of the Instrument track to an Audio Track, set the audio track inputs to that bus, record enable it, and record it in real time. |
Sin, without sounding condescending, perhaps Groove3 tutorials, for instance, Pro Tools MIDI Explained would be better time spent.
but thanks for the info! i do appreciate it!!!! -Sin |
copy instrument track to midi track | trev1238 | Pro Tools 9 | 5 | 02-04-2012 01:16 AM |
Difference between Midi Track & Instrument Track better? | paul Neathery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-16-2007 04:03 PM |
Mapping MIDI Track To Instrument Track | Delta Dreams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-08-2007 11:26 AM |
midi outputs? aux track or instrument track? | pikapikapi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-19-2006 02:28 AM |
using instrument track vs. midi+auxilary track | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-02-2006 09:21 AM |
