Problem with Mbox waking from sleep.
I received my Mbox two days ago and I am loving it. One problem I have noticed, though, is that if I put my iBook to sleep while PT is open it won't play back after waking unless I quit PTLE and restart it. Is this why Digi says to put the sleep mode to never, or is there a work around for this? The Mbox is kept plugged into my iBook through all of this. If there is no work around then what do you guys do when you go to lunch or for a break? Quit PTLE or leave your computer "awake"? Thanks
Re: Problem with Mbox waking from sleep.
I have had the same problem with my iBook. With my iMac I just have it set to never but I have shut the lid of the iBook a few times and it causes that problem.
Oh, yes there is one workaround I think, just unplug the Mbox and plug it back in. That usually helps. |
Won't PTLE quit if I unplug the Mbox?
www.piersgibbon.com www.soundcloud.com/piersgibbon VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins) Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive Backup:15 inch early 2008 MBP, OSX 10.10.2 (+Windows 7 PC running Audio TX isdn and tbu codec) Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4 |
Problem after g5 goes to 'sleep' | citychalkoutline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-10-2009 10:32 PM |
Troubles waking from sleep | avaldes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-11-2006 03:49 AM |
Sleep Mode, waking up digi?? | rose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-15-2002 06:29 AM |
g4 not waking from sleep | MilesMusic | Pro Tools TDM Systems (Mac) | 1 | 04-30-2002 01:25 PM |
Waking G4 up from sleep | macguy | General Discussion | 8 | 12-07-2000 09:44 AM |
