Incompatible EuCon version message with 3.7 and Logic Pro 10.3.2 on Mac OS 10.12.6
Hi, I'm new to the community, so please pardon me if there is a post I missed on this. I've been using Eucon 3.6 with my Artist Mix and Logic Pro and updated to EuCon 3.7 about 3 weeks ago. Ever since, I get the message 'Incompatible EuCon Version'. Current EuCon version: 4.0.3 build 138, Minimum EuCon build: 65,916. I get the message on both Mac OS 10.12.6 and on a newer instance of Mac OS High Sierra, which I'm testing with.
When I open EuCon, under Preferences, it lists the software as EuControl 3.7.0 138 built on Wednesday, October 18, 2017 at 22:06. I recall reading a post somewhere in the process about an issue with versioning/numbering/whatever-it-was, but I unfortunately did not save the reference. #dangme So... I thought I'd ping this forum to see if anyone else has perhaps conquered this matter already, or at least has some extra info...? I can launch Logic Pro without EuCon, but I'm unable to get it to work successfully. I did attempt quite a number of uninstall/reinstall efforts including cleaning up preference files via a cleanEuphonixSystem script, but to no avail. Is there an updated version I'm missing? Is there a fix or workaround, other than reverting to 3.6? Would stronger coffee be required? Thanks very much in advance. |
Re: Incompatible EuCon version message with 3.7 and Logic Pro 10.3.2 on Mac OS 10.12.
...and now that I post this, I finally see related posts. :P
http://duc.avid.com/showthread.php?t=394478 http://duc.avid.com/showthread.php?t=391693 The cleanup I mentioned is the same cleanup mentioned in this second post reference. Didn't get rid of the pop-up message. I can go ahead and run Logic, by the way, WITH EuCon, but it behaves very erratically if I do this. Usually it crashes as soon as I hit play. #extrainfo |
The message is bogus and already fixed by Apple in a forthcoming release, it has no bearing on operation.
So does this mean I should be able to use 3.7 successfully anyway in the meantime, but I'll have to click away the message 'Launch With EuCon' every time I open Logic until this forthcoming release comes out? I presume you mean a forthcoming release of Mac OS? Or do you mean Logic?
Thanks |
Correct, just click through and launch. It will be an update to logic.
Thanks very much. I'll keep the eyes open for the update. Looks like it may have only been a project or two that were causing the crashes I refer to. Guess I'll have to work through those projects a piece at a time.
Much appreciated. |
I could be a particular plugin...
if it were a plugin (in general), would it be a good enough test to go through and disable all the plugins on that project and then re-enable one at a time basically? I mean, if it were an issue with the plugin, would it generally show up as a problem at all if the plugin were turned off? Even if the plugin were still in place, it shouldn't make a call to the controller in any way, so that sounds like a test plan to me - disable all, then re-enable one at a time.
Worth a try..if you find out I can then test here and try and fix.
Thanks. If I come across anything concrete, I'll be sure to post it. I appreciate it.
Incompatible EuCon version Logic Pro X message. | SevenRising | Avid S1, S3, Dock and Control App | 12 | 03-14-2018 03:17 PM |
"incompatible EuCon version" error when launching Logic X | MowingDevil | Artist Series | 6 | 12-01-2017 08:51 AM |
[Logic Pro 9 & Artist Mix] Incompatible EuCon version at initialization | w00fa | Artist Series | 26 | 04-05-2013 06:17 AM |
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but | Patrick H | macOS | 3 | 11-20-2012 02:46 PM |
EuCon 2.6.2 incompatible with Retina MacBook | beemer | Artist Series | 42 | 11-18-2012 09:06 AM |
