Elastic Audio phase shift on multitrack drums
I'm getting phase glitches when using elastic audio on multi-tracked drums. Tracks are grouped.
When I switch the Rhythmic plug-in from Real-time to rendered, I can see some tracks shift! Am I doing something wrong? Please look at the screenshots to see what I mean. http://i203.photobucket.com/albums/a...EArealtime.jpg http://i203.photobucket.com/albums/a...EArendered.jpg Thanks, Bart
www.highlakehill.be |
Re: Elastic Audio phase shift on multitrack drums
wow thats a lot of drift!
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
Lowering the Event Sensitivity to 0% on all tracks except "SD" and "KD in" caused the shift.
No more shifting after I brought back event sensitivity to 100% on all tracks.
I've seen the same sorta thing when taking the sensitivity down to 0 in 7.4
Digi says not to do it, but often I hear glitches where the analysis markers. Now I record the fixed drums to new tracks.
I get artifacts WHEN using All tracks at at 100% sensitivity - Like using Beat Detective - I don't want the transients on Far away room mics, Overheads & The Hi Hat detected as anything I'l like to snap to the grid.
If "Digi says Not to lower the event sensitivity on other tracks" is there a "Proper - Digi qualified way / video tutorial anyone can send a link to, for fixing multi-track drums - that won't result in artifacts, and is guaranteed NOT to use the transients from a room mic in the group, as a "Quantize point" ???
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
I do it kinda like collection mode in beat detective. by that I mean I choose specific close mic tracks to snap to grid, the rest follow along.
kick and snare usually. I don't use the quantize window. I just set my grid and do it by hand. The hard part is when the client wants it drum machine tight, and not destroying the cymbals with artifacts, same problem with Beat Detective really.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
It was like this in 7.4, but some of the changes to improve the sound quality of Rhythmic in 8.0 cause these to be even more important now. If you find you've got transients in the wrong places, you'll need to work with the Sensitivity setting a bit more subtly, and perhaps do a bit of manual editing in Analysis view if they're still not quite right.
Cheers, Paul Vercellotti Avid Engineering |
If what has been stated is true, then it really only leaves the option to go through and do it all by hand unless you can quantize the kick and snare with other tracks at 0% sensitivity and then turn them back up to 100% after they are quantized.
What Pro Tools needs is the ability to select or un-select the tracks you want to be taken in account of with the quantize. Imagine how nice it would be to select just the close microphone tracks and then quantize all the tracks in the group with just the analysis markers of those close microphone tracks.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio Last edited by Dizzi45Z; 12-29-2008 at 02:54 PM. Reason: clarify a sentence |
Multitrack Drum Editing Using Elastic Audio - PT LE 8.0.1 | ryanwilsonfive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-06-2009 01:00 PM |
Multitrack drums : Elastic Audio vs Beat Detective | Jeff Knowler | Pro Tools TDM Systems (Mac) | 7 | 05-22-2008 06:52 AM |
Elastic Audio on Multitrack Drums | frenchman | Pro Tools TDM Systems (Mac) | 3 | 03-11-2008 07:48 PM |
Editing Multitrack Drums with Elastic Audio | LIQUID AETHER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-18-2008 05:21 AM |
Quantizing Multitrack drums with Elastic Time??? | Jason Rufuss Sewell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-12-2007 06:27 PM |
