Use Garage Band Library on Pro Tools
Hello everyone,
Hope you guys have all been practicing some social distancing or what have you. I want to use the library I saved/favorited using Garage Band, on Pro Tools. Is this possible? Thanks and any help would be greatly appreciated.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Re: Use Garage Band Library on Pro Tools
It's not clear how you expect this to work. What do you mean by library? You could be referring to audio sample loops, virtual instruments?, or more that are parts of Garageband libraries.
But assuming the simple case of Loops, they are stored in .caf (Core Audio) format and you could use a third party tool to convert them to a format playable in Pro Tools. Some loops are just audio, some MIDI and audio, not sure MIDI only exists. Do you want the raw MIDI or audio? You might be better off if there is a loop/audio sample you like and exporting that song to disk. But even then, once you have an extracted sample it's not going to work the same as Apple Loops, whether audio or MIDI. And it might or might not be legally OK to repackage Garageband libraries for use in other DAWs, you sure can't redistribute them as is, but the case of own-use is unclear, may run afoul of other clauses in the EULA if you reverse/engineer repackage things. Maybe safest legally to create what you like in Garageband then save song to disk and important that into Pro Tools. Or find what you are after in the Pro Tools ecosystem? Or just stay working in Garageband or Logic Pro for all or more of the workflow, especially for compositional stuff. |
You might be able to use Mainstage as a host for your instruments, but I haven’t tried it personally.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
I use MainStage via IAC bus (core midi) and record the audio analog via another interface (motu 896) into Avid Omni.
$35 for all the Logic Pro VI’s Footnote Mainstage /motu is my bootup Piano
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Pro Tools and Garage Band | tomyco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-07-2011 08:30 AM |
Pro Tools and Garage Band | caine27 | General Discussion | 1 | 10-10-2011 05:09 PM |
Garage Band with Pro Tools LE 7? | sjmagri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2006 11:55 PM |
Using Garage Band samples possible with Pro Tools? | ragbor | Pro Tools TDM Systems (Mac) | 0 | 06-24-2004 12:49 PM |
Using Garage Band with Pro Tools? | ragbor | MIDI | 0 | 06-24-2004 12:47 PM |
