Re: Pro Tools Boot Error
still no dice, have a support ticket in with Avid
Have you tried moving all AAX-plugins to the "unused" folder?
You'll find the 2 folders here (Win10): C:\Program Files (x86)\Common Files\Avid\Audio\ Move all the files, from C:\Program Files (x86)\Common Files\Avid\Audio\Plug-Ins to C:\Program Files (x86)\Common Files\Avid\Audio\Plug-Ins (Unused) and then trash prefs, restart, then try to start Pro Tools again. If it now works, one of the plugins is causing the error. Eliminate which one by moving back one file at a time to the original folder, then restarting PT to see. Once you get the error again, you know the last plugin you moved caused it. Then it's a matter of investigating whether there's an update for it, or the install was broken and you can un+reinstall it, or if the plug is simply incompatible for the time being. As for the error saying assertion in E:\ - that's not a reference to any of your disks, it's the internal path in the code that didn't execute right.
System Details Pro Tools Perpetual Scarlett 2i2 Windows 10 Pro x64 AMD FX-8120 @ 4.16 GHz, 8 Core 16 GB RAM, 1865 MHz MSI GTX 1080 Aero |
removed all aax plug ins from 32 & 64 bit folders, deleted preferences still get:
Could not complete your request because Assertion in "E:\ Code\ 222370\ ProTools\ AAE\ Source\ AAX\ CFicAAXWidget.cpp", line 822. (Use the Copy button to copy this message to the clipboard.). Pro tools gets just past the initialize audio engine then I get the error. |
What’s your interface?
Are you using a controller? I had some weirdness happen awhile back with my controller, that sounded just like this.
#16
No controller on system
Focusrite Scarlet 2i4 Gen 1 Gonna try deleting it |
#17
What happens when you run it with just ASIO as the playback device?
Are the scarlet drivers up to date?
#18
reset PC and loaded pro tools first, slowly re-adding programs.
Now pro tools is so small I cant read it and I cant figure our how to make it readable. Thoughts? Alienware 17R4 7th Generation Intel(R) Core(TM) i7-7820HK (Quad-Core, 8MB Cache, Overclocking up to 4.4GHz) 32GB, DDR4, 2400MHz Windows 10 Pro (64bit) NVIDIA(R) GeForce(R) GTX 1080 with 8GB GDDR5X 1TB PCIe SSD (Boot) + 1TB 7200RPM SATA 6Gb/s (Storage) Killer 1535 802.11ac 2x2 WiFi and Bluetooth 4.2 |
#19
What happened with this and the Avid support ticket? Bios floppy disabled
#20
Are you on a 4K screen? Check this out: http://duc.avid.com/showpost.php?p=2361859&postcount=10 http://duc.avid.com/showpost.php?p=2361795&postcount=9
Pro Tools 11.1.2 Error on boot... | lancemcv | Pro Tools HDX & HD Native Systems (Mac) | 1 | 02-18-2014 08:04 AM |
HAL.DLL error on boot | Ed Spoto | VENUE Live Sound Systems | 7 | 10-18-2012 01:19 PM |
Pro Tools 6.2 Boot-Up Error on Mac OSX | ter2333 | Pro Tools TDM Systems (Mac) | 1 | 08-30-2007 08:53 AM |
DAE Error -6 - Can't boot PT | Farmer Dave | Pro Tools TDM Systems (Mac) | 2 | 04-01-2004 11:42 PM |
PTLE won't boot....error 199? | Robocop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-11-2002 12:17 AM |
