Killer kick sound
Hi guys i need some help here no matter how I try I can´t seem to get a big sound out of my kick drum I use a beta 52 though a art mp studio v3 straight to the 001, ive also tried sending the mic to a soundcraft mixer and a studiomaster mixer but cant seem to get it right any thoughts
Re: Killer kick sound
Look I aint no pro on this but I had the same problem soo this is what I did:
if you are trying to hat that boWWWWWWW sound try removing the thing's out of your kickdrum. if you are trying to get the BO sound then place a pillow in you kick drum and place it so it leans on the side that the hitter hits. hope it help you
pardon my stinkin' writtin' |
Or replace the kick with a sampled sound. Sometimes this is the best approach.
try duplicating the kick drum track
eq one for the high clicking sound and eq one for the low end
www.klarityrecordingstudios.com |
Drums IMO are the most difficult thing to get a sound on.The best thing to do is get your self someone to help you record.Try different room setups and record just your drums for 1 minute at a time save it then try something else.Really yo just have to experiment.If you want a slap click sound go with a wood beater.Have Fun Stu
Here's some tips:
- get some weight into the kick drum, a 25lb plastic sand-filled dumbell weight works well, found at many thrift shops - remove the outer skin, extend the drum shell 2-3' with carpet in a tube shape, use the clamping rim fron the drum to hold its shape - place the mic at different spots, often works well about 1' from end of tube - cover and seal the tube with a blanket for better isolation - use compression settings with long attack (65-80ms) and a relatively short release (15-25ms), 3:1 to 5:1 ratio - large diaphram condensers work very well, but since you're using a dynamic mic, it might help to get a small diaphram condenser on the beater |
What specificially is your kick sound lacking? dDo you hear this sound acoustically? If not, then that's your problem.
where do you place the mic? what size drum, is there a mic hole? Typically I place the mic so the blue band is even with the front head if there is a hole. I find the 52 does not work that well with double headed kicks, but that's just MHO. I personally find bass drum to be the easiest to get a good sound on, however it has to sound good first acoustically. get that drum to sound the way you want it to sound when it's recorded. Ovehead sound plays a big key in the kick sound, as it is the basis (IMHO) of the drumset sound. (remember, it's one big instrument. |
hotstuff,
I did have a beta 52 that was giving me trouble (a honky sound) with the beta52 i just scooped out the honky mids after I tracked it with plugs and brought up the highs/click a bit and the mic sounded great....I found that the 52 was a bit fussy to place properly. start out by placing directly at the beater dead center about 3-4 inches away from (inside) beater head. then angle it up to the top left corner as if you were trying to aim the mic just over the bottom head/rim of the floor tom. thats where the 52 sounded best for me. Also, try to back off on the tube drive of the art, keep it at a lower gain as too not push the tube so hard. (for a cleaner sound). i did notice the 52 did not like the heavy tube color through its mids. you can also try a second mic about 1-3ft in front of the kick. a Large diaphram mic works well and I prefer a front head with a hole in it. good luck! |
Gotta disagree with you there. Overheads can pick up a modicum of kick, but really all that's audible in a mix would be categorized as room sound generated by the midrange snap. I find it's better to get the kick isolated and for room sound re-amp it in the same room through a good bass amp. I've even deliberately had my car keys and loose change rattle on a table in the room with an MC012 on them for effect during drum solos. I do agree that the overheads are the key component to the sound of the kit, but it's not one big instrument, it's an ensemble of different instruments. Cymbals, cowbell, timbale, roto-toms, snare, double-skinned toms, concert toms, kick, etc... they all require different processes to capture effectively, which is why drums can be so difficult. Ideally there should be a percussionist for each component, but that's just not how it ends up. |
Hi guys just got back from work!FREE!!! im new here and its good to see the input and that everybodys wants to help I guess the main problem might be with the acoustic sound of the kick, its a 20" with a hole in the front its got a heavy blanket in it and I use Remo heads, thanks for all the tips! Ive now got a lot of experimenting to do
No Sound - Somebody Kick me Please. | Cowboy Bob | Windows | 4 | 07-14-2011 07:41 AM |
Metallica kick drum sound? | bopsi | Pro Tools TDM Systems (Mac) | 10 | 12-23-2003 05:30 PM |
Clicky Kick sound | vlad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-01-2003 12:18 AM |
HEAVY GUITARS: correct panning in the mix for killer sound?? | marilyn manson and the spooky kids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 22 | 02-05-2002 12:09 AM |
How to get that killer electrical bass sound? | floatingpoint_32bit | Tips & Tricks | 24 | 10-09-2001 08:47 AM |
