Old 05-25-2012, 11:45 PM
wwittman wwittman is offline
Default 002 'disappears'
weird one.
working in PT 9.0.6 (0S 10.5.8) on a 002 (console)
open a new session and the 002 seems to disappear.
all of a sudden the playback engine is the Aggregate output, and the 002 option has disappeared for the menu!
restarting the 002 seems to return it to the list to allow it to be reselected.
but the problem reoccurs.
this only seems to happen with these particular sessions I am getting to mix.
but that may be a coincidence masquerading as a cause.
but it's a new problem for me for sure
ideas?
thanks
Old 05-26-2012, 07:24 PM
Default Re: 002 'disappears'
One of 2 things maybe. Bad/intermittent power harness in the 002 or maybe you have your IO setup to allow sessions to overwrite IO settings? Or maybe you need a new firewire cable?(don't wiggle it while everything is powered ON as you can fry the firewire on the 002, the computer or even both). Make that connection with all power OFF.
Old 05-26-2012, 08:17 PM
Originally Posted by albee1952 View Post
... or maybe you have your IO setup to allow sessions to overwrite IO settings?
Know where that preference is?
and it's not really I/O setting - it's the playback engine
thanks!
Old 05-29-2012, 05:26 PM
deathpoet deathpoet is offline
I am having the exact same problem with 003. It just disappears. I either always need to reinstall divers or delete playlist. Any way around this one? This is very frustrating.
LFE disappears? melodydetective macOS 3 09-26-2012 10:45 AM
PT disappears without warning ! oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-09-2009 07:33 PM
EQ automation disappears from LE to TDM mattg99 Pro Tools TDM Systems (Mac) 1 06-06-2005 10:14 AM
digi 001 disappears after a while roller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-31-2005 10:36 AM
Why kick disappears in the mix? smcoptyltd Tips & Tricks 42 05-22-2003 07:51 PM
