Installing additional Card in 192
I've installed an additional analog card in my 192... should I not see it in my Hardward Setup? I'm not seeing it anywhere... have re-booted everything.
Re: Installing additional Card in 192
As long as it's installed into the correct bay (slot 4, bottom right if look at the back of 192) and the ribbon cable is attached properly.
Then Setup > Hardware and look at your inputs or outputs (you didn't specify) 9-16 it should show up there, by clicking on the drop down menus on 9-16. ya?
There is only one slot open on the back of the 192... yes, I went into the Setup/Hardward section but did not see the extra 9-16 on the input/output sections...
did you just slide it in or did you actually remove the top and remove the cover plate to install the card
it sounds to me like you just popped in in the empty slot ?
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
I opened the top, inserted the card and carefully attached the ribbon connector..
to confirm:
did you put and A to D or a D to A card in? did you try power cycling the 192? next step, take the top off and double check the ribbon cables is seated
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I got the a/d.... 8 analog in.. can you elaborate on power cyclng? Thanks
oh yeah... many many times.. pretty frustrating. Its looking like I'm gonna have to pull it out and re-seat everything.. ??
good luck |
HD Software for additional HDX card | lasluf | Pro Tools 10 | 6 | 01-20-2013 07:46 PM |
Using a PCIe core card as additional Accel card? | Firechild | Pro Tools TDM Systems (Mac) | 3 | 07-30-2012 10:48 PM |
OT:installing additional RAM problem | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 12-15-2004 06:29 PM |
additional card for wavelab | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-04-2002 11:08 AM |
Installing additional audio suite effects on PTF | kastlercreative | Digidesign Hardware & Software | 1 | 10-15-2001 10:23 PM |
