Old 04-21-2013, 06:21 PM
Southsidemusic's Avatar
Default How to get the plugin latency metering working
Hi friends
Sorry to ask such a Noob stupid question but I read somewhere here a few months ago about somebody who had a problem with latency in certain PI's and got the advice to check something with latency monitoring and it is located under a channel strip in MiX window. I have turned it on I thought but the metering is just like it is "locked" and nothing happens and nothing is showing. Just the "green" little screens and where it is supposed to show freen/yellow/red there is nothing happening, just some digits but I can't change or do anything to those settings nor to show anything?!. Yes Yes, I know I am wording this like a complete tool but as I can't find what it is called I can only explain where it is located and what it shows
Is there a setting to get that metering showing latency or plugin cpu usage or is it only when you have HDX or Native PCIe card installed?
Many Thanks to all you guys and sorry for such a [bleep][bleep][bleep][bleep]ty post wording
PS. What I am looking and asking for looks like this picture up top in the channel but in our mac it is on the bottom under the channel and "make inactive" settings.
http://www.flickr.com/photos/6936867...in/photostream
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-21-2013, 06:44 PM
Question Re: How to get the plugin latency metering working
View-->Mix-->Delay Compensation ?
Old 04-21-2013, 06:49 PM
Default Re: How to get the plugin latency metering working
Sorry for this but how stupid it may sound we actually only use the basic features of PT10HD after moving back to PT from a 6 yr stint with Logic Pro so many of the features we used in PT6.7HD back in 07 are soo updated and awesome that we have not yet taken time to understand them all.. so do I goto view and then mix and click delay compensation or what does that mean!?
Thank you for helping us out Jonathan, Really nice of you
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-21-2013, 07:16 PM
P,B,S P,B,S is offline
As far as I know there is no latency meter per say.
BUT
What some people do to see exactl how much latency theyare experiencing is.
If the plug you want is suppossed to work instantly like say a eq.
Make a aux track, send audio to the aux track with your plug on it,
Then put the aux tracks output to a audio track, now record on that audio track.
When you have your audio with the plugin efx recorded on it. Switch to samples instead of bars beats or minutes seconds.
Now nudge the new track back using samples as your nudge , until both tracks line up perfectly. That is your latency in samples.
But it usually just tells you in the delay comp at the bottom of the mix window. If the plug is on the track and not on a bus
Old 04-21-2013, 08:09 PM
Hi P,B,S,
That is exactly what I mean but how does one turn it on
That delay comp you refer to doesn't work or we have done something wrong!
How do you activate that and do we need any extra settings done for it to display properly?
Thank you for your input and hope one of you know what to do
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-21-2013, 09:10 PM
crizdee's Avatar
crizdee crizdee is offline
First you turn delay comp on in the playback engine settings!
Then as Chief Technician said, to view the delay comp in the tracks view. Go to... View-mix-delay comp.
Now the delay comp will display at the bottom of each track.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-21-2013, 09:50 PM
ArKay99 ArKay99 is offline
If you just want to see it in the little window under the fader and meter, just hold Command and then click on vol. As you click, it will cycle from vol, to pk, to dly, and then back to vol. Delay compensation doesn't need to be turned on for this.
Is that what you want?
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
Old 04-22-2013, 10:14 AM
Originally Posted by crizdee View Post
Chris
Hi Chris
Thank you soo much for that clarification I didn't understand how to getnit setup on the playback engine settings but now I do :)
Thank You ArKay99 aswell for your input, much appreciated guys
Thanks again and really glad this forum exists with all the help you supply us with! Just great stuff :)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-22-2013, 10:15 AM
Spot on
Thank you ArKay99!
That is exactly what I wanted to know.
Many thanx for the input
Best
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-22-2013, 10:47 AM
Don't forget, under the Options menu, there is also a spot to turn it on/off
Guitar Rig 5 (or any plugin really) and PT Metering dougdude9 Windows 2 07-03-2013 06:58 AM
Good Plugin for Loudness Metering (EBU R128) Meads Pro Tools 10 4 06-01-2012 04:08 AM
Plugin metering on SC48 Limelight VENUE Live Sound Systems 2 01-23-2012 10:08 AM
K-System Metering plugin? ZoDMeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-11-2009 10:28 AM
Wanted: MASSEY Metering plugin! postprosound Post - Surround - Video 7 12-08-2006 07:59 AM
