#21
Re: Mic Inputs Very Low (AGAIN WTF!!!) w/ Mbox 3
Have you tried a different dynamic mic? is it possible the Peavy mic is defective or damaged? Just a thought.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#22
I am having the same exact issue with my MBox. I also own a 3rd Gen MBox. I have use it several time before and the level were perfect. A few days ago it was giving me lower than normal levels. Even when I crank the gain all the way up, I am getting just around -10dB on the meter. I plugged my MPC1000 into the TRS and the levels are fine. Someone here mentioned that the TRS bypasses the mic preamp. Maybe that's the issue. A hardware defect with the MBox mic preamp.
#23
Well, ijust bought the MBOX3 mini(was using the mini2) . I Mic my Tube AMP at the grill cloth with a SM57,(yes xlr's on both ends) I have to turn my Amp up to an uncomfortable level and the input gain Knob on the MB3 to over 3/4's., to get a good unity gain input level in Pro tools LE 8.05. This does not seem right .. Shoudl be able to play softer and turn up the input. Is this typical ? or did I get a lemon?
#24
I've been having this problem with the Mbox 3 Pro, also. I haven't been able to figure out the cause of it and it just seems to correct itself over a couple of days. I have found this interface to be a very reliable paperweight at least. So yeah, swings and roundabouts.
#25
I don't know if it's an issue rather just how it works. Monitored mic signals have been lower than instrument signals on all devices I have tried.
But is it both the monitored and recorded signal that's low or just the monitored signal? If it's just the monitored signal I would check that the input faders in the mbox mixer panel are turned all the way up. If it's the recorded signal aswell I would borrow a good external preamp and check if the line signal is stronger. |
#26
Each gain knob has an option to pull outward and create a -20 db pad. Try pulling the knob in and out and make sure you hear a clicking noise. The knobs are designed really poorly and could easily get stuck in the -10 db pad position. Try that!
Windows 7 64 Ultimate: SP1 PT 10.3.8 ------------------------------------------------------ ¨WHERE´S MY CHECKBOOK?¨ https://soundcloud.com/louieshowers Last edited by louieshowers; 12-26-2013 at 11:12 AM. |
#27
#28
The "sweet spot" for that interface is almost at the very top of the available gain. I have one, but I use it in conjunction with a mixer... So I feed the line inputs. But for a time, I was using the mic pres on the MBOX itself, and never encountered an issue with low gain ( on either dynamic or condenser)
I see the issue you're identifying, but it isn't necessarily a problem. The levels in the pic you shared were fine for vocals - I would back off the gain for that guitar recording, though. On the other hand, you really should find it easy to clip the input with the gain maxed, with most microphones. That's the first thing I thought when reading the thread title. It's a 20 dB pad, by the way. |
#29
Ps. I have found that using the pull out pad feature for guitars/bass is a must..it definitely provides a better sound and reduced signal in my experience. And allows you to set the input knob at about 2 or 3 o'clock or so.
Windows 7 64 Ultimate: SP1 PT 10.3.8 ------------------------------------------------------ ¨WHERE´S MY CHECKBOOK?¨ https://soundcloud.com/louieshowers |
#30
Mine has a hefty "click" you I can both feel and hear... But I don't use it that often. Maybe the something in there wears down after awhile.
More inputs than Mbox 2 | jordan_ellipsis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-29-2007 02:40 PM |
How many inputs with Mbox 2 pro | Brad Summerfield | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-06-2006 08:26 AM |
TRS inputs on MBox | Marker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-26-2004 10:35 AM |
Using the TRS inputs on the Mbox | djrocksteady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-16-2004 03:33 PM |
Inputs on MBox | BlackOctopus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2003 02:05 PM |
