Old 01-17-2013, 08:23 AM
rgriff rgriff is offline
Default partitioning a 2 TB or seperate drive to record?
I just got a 27 in imac with a 2 TB drive. can i partition it and use pt 10 and record to the partitions, or do i need to use my firewire drive to record to.
It will be in a chain with my 003. Or any suggestions ?
My imac is last years model, but it has Mountain Lin on it.
I have a Snow Leopard OS as well, which should I use?
Does ML work with PT 10 yet ?
As this is a new mac, i don't have my PT 8 on it. Do i need it installed to download PT 10 ?
Thanks
RG
Old 01-17-2013, 09:11 AM
sunburst79 sunburst79 is offline
Default Re: partitioning a 2 TB or seperate drive to record?
Thanks
RG
Yo need a separate drive not a partition. ML is approved for PT10. Make sure you use the latest PT update and drivers. You may have to experiment with the order of the devices on the FW chain. I would go iMac>FW Drive>003 first and see how it works . You may need a FW800 to FW400 adapter.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-17-2013, 09:44 AM
Thanks,I thought I would need the other drive
Ray
Old 01-17-2013, 09:52 AM
Is there a preferred 400 to 800 fire wire adapter? I read some do not work.
Thanks
Old 01-17-2013, 10:06 AM
nst7 nst7 is offline
Belkin seems to work well. You can get them at Guitar Center and maybe even Best Buy.
In your situation, since you have last years Imac, you have Thunderbolt. You should get the Apple Thunderbolt to Firewire adapter ($29). Use that for your 003, and put the audio drive on the FW800 port. That way they're on two different busses with no daisy chaining issues.
And when you get the PT10 upgrade, it's a full installer. No need to first install your older version of Protools.
Old 01-17-2013, 10:10 AM
Thanks ! I did not know about the thunderbolt to fire wire converter.
And I really appreciate the upgrade help !
RAY
No Audio, But Just Samples. System Drive Or Seperate Drive. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-10-2010 03:47 PM
Tips on Partitioning OS drive + 2nd Media drive DaveSB Pro Tools TDM Systems (Mac) 0 07-26-2006 02:15 AM
Partitioning Audio Record Drive brianjanthony Pro Tools TDM Systems (Mac) 6 06-14-2005 12:05 AM
Partitioning new FW Drive TULL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-30-2004 09:47 PM
FW Drive partitioning in X.3.2 emf1138 Pro Tools TDM Systems (Mac) 5 03-03-2004 05:09 PM
