Connect mBox 3 to Pro Tools
i recently got an mBox 3 and i am having trouble connecting it to Pro Tools, i want to record guitars so i go new track, mono audio, then i go to select an input and the mBox does not show up, it just shows built in inputs and microphones. I want to know how to get inputs and outputs through the mBox, please help!!!!
Re: Connect mBox 3 to Pro Tools
Make sure the Mbox is selected as the Playback Engine in Pro Tools (Setup > Playback Engine). Once this is done you should be able to choose an Mbox input on an audio track.
The playback engine is the mbox, what would the input and output be called if I had the mbox connected?
Probably something like "Mic/Line 1", "Mic 1", "In 1" etc. If it's still showing the same inputs, go to Setup > I/O and click "Default" on the Input and Output tabs with the Mbox still the Playback Engine.
I think that worked :) thank you so much
Mbox Pro Pro Tools 10 Bundle to Mac Book Pro Connect | Rusallah | Pro Tools 10 | 3 | 09-11-2015 09:24 PM |
MBOX 2 won't connect | asterix2k10 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-09-2010 06:01 PM |
Safe to connect a different Mbox 2 to an already-installed Pro Tools system? | bewareofdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-20-2010 10:31 AM |
Can't connect to Mbox 2 with Pro Tools 7.4.2pr | jazdon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-02-2008 02:53 PM |
How can I connect both Mbox and G5 to monitors?? | tokyofan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-11-2005 03:50 PM |
