Plugin metering on SC48
Hey guys!
On the center section of the console under the channel meter is the gain reduction meter for the channel compressor. Under that is the plugin gain reduction meter. I have yet to see that work on the SC48 when I have inserted compression on the channel. Anything I'm missing? Should the expected behavior be that the plugin gain reduction automatically shows the GR if a compression plugin is inserted on that channel when the channel is selected? Thanks!
Chris Hunt McKinney, TX SC-48 3.0/ ProTools 10 / Mac Book Pro 13" i7 / Limelightband.com
Re: Plugin metering on SC48
You will only see that when the com plug-in is focused in Ch Ctrl Section. Press Comp then Plug-In. This is because you can have more than one Dynamics plug-in. Try adding an Exp/Gate plug-in after the comp plug-in. They both can show gain reduction. The meter will display properly for the selected plug-in.
Doug Sjostrom |
Gotcha, thanks Doug I'll try it out this week.
Guitar Rig 5 (or any plugin really) and PT Metering | dougdude9 | Windows | 2 | 07-03-2013 06:58 AM |
How to get the plugin latency metering working | Southsidemusic | macOS | 10 | 04-22-2013 02:19 PM |
Metering LEDs on SC48 | burpeee | VENUE Live Sound Systems | 1 | 09-27-2009 08:33 AM |
K-System Metering plugin? | ZoDMeister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-11-2009 10:28 AM |
Wanted: MASSEY Metering plugin! | postprosound | Post - Surround - Video | 7 | 12-08-2006 07:59 AM |
