Old 10-27-2009, 03:16 AM
Swar Swar is offline
Default Increasing the height of Wave form display
Is it possible to adjust the waveform display size of only one track... when we try to do with small button on right hand top of the edit window all the tracks increase or decrease proportion and some tracks become too dense.
Old 10-27-2009, 06:38 AM
daeron80 daeron80 is offline
Default Re: Increasing the height of Wave form display
You didn't say what version, but in 7.x (probably the same in 8.x):
1. Select the Zoomer tool (F5)
2. While holding Command+Control, click and drag vertically.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-27-2009, 07:30 AM
Or put the cursor at the lower edge of the track so it changes to a different symbol, and drag the lower edge down to whatever size you want.
Old 10-29-2009, 09:42 PM
RadioMoo RadioMoo is offline
...or select the track and hold Control and use the up arrow...or select the track and hit Control+E.
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM
Old 10-30-2009, 09:22 AM
My instructions are for how to vertically zoom in on the waveform. The others, I think, are for how to increase track size. Hopefully one of those is what you're after.
David J. Finnamore
Old 10-30-2009, 10:37 AM
Thanks for all your replies. But this was not my question, perhaps I didn't articulate it properly.
Let me try again with an example
1. Track one has vocals which you record first
2. Track has Guitars which record second
3. Track 3 has Bass whihc you record third
4. All the 3 above are wave forms view
5. Now as each of these are recorded the actual wave form inside track is of different size while the track height is same
My question if you try to change the height of the wave form or Density of the wave form of one track and all the tracks in edit window change by the same proportion i.e. the vocal becomes really thick dark (onl the wave display nothing hasppens to the actual audio)
Now the only way I know is to go to the small button in the right hand top of edit window and click the bottom half until all the tracks/regions become just a single line and then press the top half of the button for the wave forms to become visible size again
Hope this clarifies... I am on PT 8.01
cheers
Old 10-30-2009, 11:32 AM
That's the scenario I was answering. Does
not work in 8.x? Must be something similar, at least.
David J. Finnamore
Old 10-30-2009, 06:57 PM
K Roche's Avatar
K Roche K Roche is offline
Try putting the cursor in the particular track you wish to change the waveform size in, and click it. Then in the area above the tracks you will see in the upper left middle, a box which has Icon buttons which look something like left arrow then a waveform with an up arrow above and down arrow below it, this will change waveform size for the selected track only . the one in the upper left of this pic
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 11-03-2009, 12:09 AM
Thanks . I tried selecting the track and region and moving the arrow on left hand top but all the wave forms in the edit window in every track increases or decreases.
Old 11-03-2009, 04:20 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Would this help...?
Control + Drag with Zoomer Tool up or down in the track...
Check also page 22 / Table 35 in PT Shortcut's Menu...
G
MacBook Pro M2 Max / Pro Tools 2024.3.1 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
Adjusting the wave height on a single track jackp Pro Tools TDM Systems (Win) 4 02-13-2016 01:49 PM
Increasing display font size MboxToo Tips & Tricks 1 05-06-2009 06:17 PM
Wave form mandolinman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-05-2008 09:55 AM
How to change individual wave height ? Paul B. Pro Tools TDM Systems (Mac) 13 05-11-2007 10:35 AM
Track Height/ Data Display Menus JKD99 Pro Tools TDM Systems (Mac) 4 07-04-2000 05:31 PM
