Parallel Drum Compression
I want to start using this technique, but my initial results have not been the greatest. I'm using EZ Drummer with my own patterns to make a song.
I'll bus all those (instrument) tracks into a stereo audio track and print it. When I go to line it up with the original MIDI track and hit it with the compressor, (so far only BF76), no matter which way or how much I nudge, there is some kind of comb filtering, phasey sounding thing happening. Not sure where the mistake (if any) is being made, but it's not giving me the results I need. Do I need to have Delay Comp on when printing the track...or after when lining it up? Should I not be printing the Room and OH tracks from EZ Drummer? Anyone who does this frequently, give me some insight please
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
Re: Parallel Drum Compression
Do you have Automatic Delay Compensation turned on?
Your problem comes from trying to line an audio track up exactly with an instrument track. Once you've printed the audio track, disable the instrument track.
Now, you could do a couple of things to get the parallel comp, but a real easy way is to copy the audio track and add your processing to one while leaving the other clean. Also make sure that delay comp is turned on.
Yes ADC is on. If I disable the Instrument track, doesn't that cut out the original EZ Drummer track? I need it to play WITH the printed track, yes?
I will also try copying the audio track and processing one of them. I thought about printing the Room and OH tracks, and maybe turning those off on the Instrument tracks after, so as to eliminate any other phasing? Not in the studio at the moment... Thanks!
Another solution, which does cost some money, is to use the new Waves HComp, which has parallel compression built-in, by way of a mix control. It also happens to be a great sounding compressor, and works exceedingly well in this application. |
I bussed all the tracks to an Aux as well at the main outs, and put the compressor on the Aux track, and am getting good results so far with no phasing. I use the RTD process in my sessions, so all tracks get routed to a submix Aux by default, and then this has it's own Aux. I will try the idea of having the plugin on both channels, as you mention to avoid ADC, and see how that goes.
Thanks for the responses...
Parallel compression without using groups | Robert I | VENUE Live Sound Systems | 6 | 09-09-2010 06:59 PM |
Parallel Compression in the box. | FraserTSmith | Tips & Tricks | 8 | 05-04-2006 09:21 AM |
Parallel Compression? | SoundguyJP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-28-2006 06:38 PM |
NY/Parallel Compression - Questions | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 07-19-2005 08:52 PM |
Parallel compression and 6.4 | Aquarius | Tips & Tricks | 2 | 07-05-2004 03:05 AM |
