Can\'t connect to Mbox 2 with Pro Tools 7.4.2pr
Just did a new installation of Pro Tools LE 7.4.2pr after uninstalling (clean uninstall) previous versions.
When I try to open PT 7.4.2pr, it starts loading, then I get message: "Unable to locate Digidesign hardware. Make sure your hardware is connected and turned on.". Never get a chance to enter my authorization code. In system preferences when I click on Digidesign MBox 2, I get the message :"Unable to connect to MBox 2". It also says: "firmware version<not available>". Is there a separate driver I have to download for the MBox 2. I was under the impression that the download is a complete package and that nothing else is needed. Anybody else out there having the same problem and if you solved it, HOW? Am running 10.5.3 on an iMac2.4 GHz Intel Core 2 Duo. 2 gigs ram. Thanks in advance for your help. Don |
Re: Can\'t connect to Mbox 2 with Pro Tools 7.4.2pr
I would check and make sure that nothing in your setup has changed since the previous version of Pro Tools was finding it...for example make sure that it's not being run through a USB hub, try another USB cable, make sure it's plugged into the left usb port on a MacbookPro or one of the rear USB ports on a Mac Pro. If that still doesn't bring up anything, test the Mbox on another machine if you can.
hello!
same problem here... imac core (1) duo with 10.5.3 greets, martin
Intel i7 @3.5 GHz running OS X 10.8.2 – MacBook Pro 2.33 GHz C2D from 2007 – Logic – RME Fireface 800 – Eleven Rack with Expansion Pack – Pro Tools 9 |
Mbox Pro Pro Tools 10 Bundle to Mac Book Pro Connect | Rusallah | Pro Tools 10 | 3 | 09-11-2015 09:24 PM |
Connect mBox 3 to Pro Tools | wheelzthatkillz | Pro Tools 10 | 4 | 03-30-2012 10:00 PM |
MBOX 2 won't connect | asterix2k10 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-09-2010 06:01 PM |
Safe to connect a different Mbox 2 to an already-installed Pro Tools system? | bewareofdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-20-2010 10:31 AM |
How can I connect both Mbox and G5 to monitors?? | tokyofan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-11-2005 03:50 PM |
