Old 03-17-2007, 09:19 PM
hec hec is offline
Default 7.3 Will not start after MacOS Update
ptle 7.3.1 will not start after I installed some updates (done 3/16/07) on my mac (via software update). When I click the icon (or double click in finder) the software appears to try to launch but then stops with no visible error or dialog.
I have an imac 2Ghz core duo, 1.5 gb ram and am using an Mbox2 (factory bundle).
It was running fine prior to the software update. Is there a simple solution to get it up and running or do I have to install everything again?
Thanks for your help.
Old 03-17-2007, 09:23 PM
Default Re: 7.3 Will not start after MacOS Update
Read the Announcements forum.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-18-2007, 04:34 AM
ingilizanahtari ingilizanahtari is offline
As a Protools and Mac newbie, I just did not read the forum before updating, and installed the 10.4.9 combo updater. I have the same non-starting behaviour ONLY when I plug in my Mbox 2 when my Mac Book Pro (15" Core2Duo 2.33) is on. It seems to work perfectly after a restart, with the Mbox 2 plugged in though.
Old 03-18-2007, 08:07 AM
Brad Gillie Brad Gillie is offline
Don't use Software Update to update your system. Go to Apple's website and download the combo update.
Possible??Update M-Powered8 to a version compatible on MAcOS Lion??? libellus Pro Tools M-Powered (Mac) 0 11-10-2011 12:37 AM
update PT 8.0.4 to 8.1 and MacOs 10.5.6 to 10.6.4 matt_the_manic Pro Tools TDM Systems (Mac) 5 09-16-2010 08:46 PM
PT LE 8.01 stopped working after MacOS 10..8 update on 09/02/2010 ericmedley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-07-2010 12:32 PM
PT LE 8.0cs2 Update not showing on start up reycantong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-15-2009 11:10 PM
2.4 update / ID start time problem.... Tad Bush Digidesign Hardware & Software 0 08-20-2001 02:52 PM
