Old 06-30-2004, 03:41 PM
Aquarius Aquarius is offline
Default Parallel compression and 6.4
Hello,
Could someone explain to me how to create my routing for this ?
I'd like to use the Impact comp because a friend of mine is bringing a soundfile he did on the new SSL to compare....
I'm getting confused with the ADC...
Peace,
Olivier
Old 06-30-2004, 04:04 PM
Drew Mazurek's Avatar
Default Re: Parallel compression and 6.4
Just make 2 stereo aux inputs set to the same input and route your group members to them. Put a comp on one but not the other, done. ADC will do the rest.
drew
www.drewmazurek.com
Old 07-05-2004, 03:05 AM
Thanks Drew
Peace
Parallel Compression Routing Mack Truck macOS 10 02-06-2012 08:41 PM
parallel compression sends? Khatru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-15-2009 08:58 AM
Parallel Drum Compression soundboy35 Pro Tools TDM Systems (Mac) 6 06-02-2009 11:42 AM
Parallel Compression in the box. FraserTSmith Tips & Tricks 8 05-04-2006 09:21 AM
Parallel Compression? SoundguyJP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-28-2006 06:38 PM
