Old 03-02-2007, 10:34 AM
mookie36 mookie36 is offline
Default Format????
Hi all.
Pulling my hair out.I've been working on a track, i went to bounce
to disk,which it did,but when i came to burn it i get a message
'Blah blah blah is not a sound file,or is not a supported format'.
I've never had this come up before.Don't know what i've done wrong :c(
Since this, i've tried to burn other sessions but get the same thing.
It wont burn anything from pt.It's the first time it's happened in 7
years and i got a gig coming up.Any ideas please?
Many thanks
J
Pt Le,001
Mac G4
Yamaha 8/4/24(little git)
Toast 3.5.7
Old 03-02-2007, 04:01 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Format????
List the converted file as in type, bit depth, sample rate, etc.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 03-02-2007, 05:57 PM
RadioMoo RadioMoo is offline
Did you make sure "Enforce Mac/PC compatibility" box was checked when you created the session? If not, you won't have the extension after the file name. Try just adding the .aif or .wav extension and see if that cures it.
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM
Old 03-03-2007, 03:14 AM
Hi.How do i do it?when i start a new session all i get is the bit depth(16 or 24,and i always use 16).
Many thanks
Old 03-03-2007, 07:55 PM
Many thanks
There's a checkbox in that same dialogue box where you choose bit and sample rate, that says "Enforce Mac/PC compatability"; make sure to click that box so there's a check mark in it.
To add an extension to a filename, click the filename and it will "highlight"; hit the right arrow key, which moves the cursor to the end of the filename, and type either ".wav" or ".aif" depending which extension is appropriate.
Old 03-04-2007, 06:59 AM
jre3132 jre3132 is offline
Any ideas please?
If you haven't already, search for the difference in Bounce to disk and Record to track. There are some pretty good debates, but Record to track seems to win out being better quality. That might also solve your problem since you'd be exporting a file instead of bouncing.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Best format for PT Kenmillerjr Pro Tools TDM Systems (Mac) 4 12-30-2010 03:03 PM
Wave Format Extensible file format? Joe Mendelson Post - Surround - Video 8 01-07-2008 05:18 PM
best HDD format dailan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-17-2006 06:10 PM
I'M ABOUT TO FORMAT MY HD!!!!! badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-23-2003 02:09 PM
HFS or HFS+ format? Rob Macomber Pro Tools TDM Systems (Mac) 4 06-20-2001 10:49 AM
