2019.10 installation error
An error at the installation :
Database: Transform: Cannot update a line that does not exist. Table: shorcut. Solution ?
Re: 2019.10 installation error
Permission issue possibly. Make sure you are running the installer locally and try running setup as administrator.
Thank you. No, that's what I did and it does not work. I have never seen this kind of message.
Re download perhaps.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Had the same issue.
Removed ProTools 2019.06 cleaned the registry restarted computer and did a new installation of ProTools 2019.10. That fixed the problem Hope that helps
Win11 Pro, Gigabyte X299 UD4 Pro, Intel I7 7820X 64 GByte RAM, 4*WD 1TB Disc - Black-Version, Samsung 970 Pro 1TB-SSD Steinberg UR22C, Focusrite Saffire Pro 40 with OctoPre MKII, Plugins from Izotope, Fabfilter, Waves and others. ProTools 2023.9.0, Cubase Pro 12, Wavelab Pro 11 |
Thank you, I do that.
I have the same installation error here with the new Update 2019.10 over my version 2019.6 under Windows 10 Pro Build 1903 with latest MS-Hotfixes.
I have created a Supportticket and maybe the get further logs from my System. Seems to be a missing system folder path as i saw in the installation log dialog (but not shown with installation-path he dont find). New Installation after PC Reboot and Installation with admin rights dont helps. But i have also Cubase Pro 10.0.40 beside Protools as the other both Users in this Thread with the same Issue ? |
I uninstalled PT 2019.6, and then cleaned up the registry with CCleaner. The 2919.10 installation then worked.
I had the same issue, installed via Link. I think it's serving up the wrong file. I downloaded the installer via avid site and everything works fine. I didn't do any uninstalling or registry cleaning. Win 10 1903.
I my case its equally if i choose the direct download or the ZIP package via Avid Link.
2019.6 strange installation errors... | WKG | Pro Tools 2019 | 1 | 07-21-2019 05:59 AM |
0 can`t right error since PT 2019 installation, Good Job Avid | spock999 | Pro Tools 2019 | 0 | 05-16-2019 11:50 AM |
error message during installation error 2147213312 | pianovasano | Pro Tools M-Powered (Win) | 1 | 08-31-2010 07:52 AM |
new PT LE 7.4.2pr installation error | wiseman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-01-2008 12:02 PM |
installation error | john321 | Digidesign Hardware & Software | 1 | 06-27-2004 01:56 AM |
